ICMP Unreachables on Layer3 Switch
Philip91
i try to ping an unreachable host to generate an icmp unreachable message on our 3750. I also tested it with an 6500. It didn´t work.
ip unreachables on the Layer3 Interface is enabled
Then I tested it with a basic Router and it worked fine. On Nexus 7k it worked also.
Does everybody know if an Layer3 Switch generally sends ICMP Unreachables ?
To me it should because of:
sh ip interface vlan 40
ICMP unreachables are always sent
Philip
7 Replies 7
Raju Sekharan
Do you have any  mls rate-limiter, control-plane policing, acl or qos blocking ICMP un-reachable messages
Thank you
Raju
No nothing of that
Can i verify with an debug command that my Layer3 Switch sends out the packets or not ?
I sniffed at the network card of my computer with wireshark and there were no icmp reply
You can do " deb ip icmp" and check if you are sending unreachables
Thank you
Raju
if you want to see debugs for transit traffic you'll have to disable ip cef for the interfaces with no ip route-cache cef command
Regards.
Alain
i made an debug on the switch and there is no output of any unreachable packets.
in the debug of the router i thought every unreachable message.
Is that a correct behavior ?
What is the IP you are trying to ping?
Can you collect below output from 6500
1. Show ip cef
2. Show ip traffic
Thank you
Raju
i did it on an 3750G
show ip cef 192.168.251.200
%IPv4 CEF not running
show ip traffic
ICMP statistics:
  Sent: 0 redirects, 0 unreachable, 15 echo, 73360 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp
        0 info reply, 0 time exceeded, 0 parameter problem
        0 irdp solicitations, 0 irdp advertisements
