Setting up Switch module on 2951
Patrick McHenry
Level 7
Level 7
I'm trying to set up a 2951 with a 24 port switch module. I want the ports to act similiarly to the ports on an 881 router - where I assign the VLANs on the router and I set the VLANs to the switchport interfaces.
I would like to be able to create the VLANs on the router portion of the 2951 and then, enter the switch module and configure the Ports to the VLANs but, how do I logically connect router to the switch? Is it an internal logical interface - meaning how are the VLANs getting from the router to the switch?
Thanks, Pat.
24 Replies 24
Reza Sharifi
Hi Pat,
You need to configure the routers gi1/0 interface first using a console cable before you can access the switch module and configure it.  This is the interface that connects the router to the switch
To configure an IP address  and subnet mask for Gigabit Ethernet interface (gigabitethernet 1/0) on  the router, use the following command:
Router(config)#interface gigabitethernet 1/0
Router(config-if)#ip address 10.1.1.111 255.255.255.252
To open a session from the router to the Cisco enhanced EtherSwitch service module, use the following command:
Thanks Reza,
I've done this. I can get into the switch module doing it the same way you described. My problem is how do the router and switch communicate the VLANS? Is there an internal switch fabric between the two like the 881s?
For instance; on the 881s I configure the VLANs and VLAN interface  IPs on the router then, I configure the switchports to a VLAN. I'm wondering where I should configure the VLANs and their ip addresses - on the router or switch and how do the router and switch module exchange data between them?
Thanks, Pat.
Pat,
If I remember correctly, it is the last port on the switch module.  do a "sh ip int bri"
If you have a 24 port module, than it should be port 25 or 26.
Thanks Reza.
What are these interfaces - are they the connection to the router? If so, do I configure them as trunks to use the VLANs that were configured on the router? And, what interface on the router connects to them, if any?
Thanks, Pat.
Pat,
If the interface is in up and up mode, do a "sh cdp nei" it will tell you what port on the router it is connected to. It may be gi2/0 but not sure
Switch#sh cdp neigh
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
mchenry.pcc.int  Gig 0/26          169              R S   CISCO2951 Gig 2/0
mchenry.pcc.int  Gig 0/25          142              R S   CISCO2951 Gig 2/1
Switch#
I did a ctrl shift 6 then x
Then I go into the router...........
mchenry#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         unassigned      YES NVRAM  down                  down
GigabitEthernet0/1         172.17.0.17     YES NVRAM  down                  down
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down down
GigabitEthernet2/0         1.1.1.1         YES manual up                    up
GigabitEthernet2/1         unassigned      YES unset  up                    up
NVI0                       unassigned      YES unset  administratively down down
Tunnel0                    172.20.68.12    YES NVRAM  up                    down
Tunnel1                    10.3.68.12      YES NVRAM  up                    down
Vlan1                      unassigned      YES unset  up                    up
mchenry#
So it appears that I'm connecting to the switch module through gig2/0 on the router for management but , this still doesn't answer the question I have for configuring. I want the connection between ther router and switch module to be layer 2. Should I make the g2/0 on ther router and the g0/26 on the switch trunk ports. Or is ther a more elegant way of doing this?
By the way what is the embedded-service-Engine0/0?
Thanks, Pat.
Correct, you would need the trunk 0/25 on the switch side and 2/1 on the router side since they are neighbors.  These are internal interfaces.
OK.
What about the g0/26 to g2/0 link? Should I just shut that?
It would seem weird to me to have one layer 3 connection and one trunk connection, wouldn't it? Or, is this the way it is done?
Thanks, Pat.
Isn't gi2/0 (ip 1.1.1.1) the one you use to session to the switch? If yes, than you need to have this interface in up and up mode in order to get from the router to the switch.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/cimce/1.0/configuration/guide/CIMCe.html#wp1104930
Reza,
I'm trying to understand this concept of the switch module inside a router and I'm not getting any closer.
The config will have 2 VLANs - 10 and 30 both sharing the same subnet and IP. 10 will be for data and 30 will be for voice.
So, should I create the VLANs on the switch then, configure a VLAN 10 interface and a VLAN 30 interface on the router? And create a trunk between the router and switch. g2/1 on the router and g0/25 on the switch?
Thanks, Pat.
Pat,
First, usually you assign one vlan to one subnet and not 2 vlans to one subnet.  It does work, but it is not common and also confusing.  So, if you are planning 2 have 2 vlans, assign a subnet to each. Specially since one of your vlan (30) will be used for voice, it is always a good idea to keep the voice vlan/subnet separate from data.
Example:
192.168.10.0/24 vlan 10 data
192.168.30.0/24 vlan 30 voice
Now, let me explain the switch concept.
Think about the switch module as regular 3560 switch.  As a matter of fact the switch module inside your router runs the same image that you load on a standalone 3560 switch. Now, you create 2 layer-2 vlans (10 and 30) on the switch module.
config t
vlan 10
name data vlan
config t
vlan 30
name voice vlan
now, you trunk interface gi0/25
On the router side you now add 2 sub-interfaces to gi2/1 (one for vlan 10 and one for vlan 30)
example:
config t
inter gi2/1.10
ip address 192.168.10.1 255.255.255.0
encap dot.1q 10
inter gi2/1.30
ip address
192.168.30.1 255.255.255.0
encap dot.1q 30
So, the route routes between vlan 10 and 30.
It this more clear now?
Reza
Thanks for answering so late.
Yes that does clear things up a lot!!
I know the 2 VLANs on one subnet is a little confusing but, that is how we have been deploying the 881s to remote users so, I'm going to keep it standard for the small office-2951s.
This brings up some more questions:
I'm a little confused about the g2/1 and g2/0. Does Cisco give you 2 of these "logical"  interfaces for the purpose of what I want to accomplish - provide a trunk between the router and switch module for passing VLANs or I gues you could keep it an access port for a flat network using one interface and also provide a layer three connection for management using the other?
Thanks, Pat.
Thought I might include this to give you a better idea of what I am trying to accomplish.
This is the VLAN interface configs on the 881s:
interface Vlan10
description Corporate Access
ip address 172.16.0.209 255.255.255.248
no ip redirects
no ip unreachables
ip nat inside
ip inspect cvo-inspect in
ip virtual-reassembly
ip tcp adjust-mss 1360
no autostate
service-policy input mark_incoming_traffic
interface Vlan20
description Guest Access
ip address 192.168.68.1 255.255.255.0
ip nat inside
ip policy route-map pbr
no autostate
interface Vlan30
description Corporate Voice
ip unnumbered Vlan10
ip access-group allow_skinny_acl in
ip inspect voice in
no autostate
end
Vlan1                      unassigned      YES TFTP   administratively down down
Vlan10                     172.16.0.209    YES manual up                    up
Vlan20                     192.168.68.1    YES manual up                    up
Vlan30                     172.16.0.209    YES TFTP   up                    up
I'm thinking I could create the same config with the 2951 but use the sub-interfaces like you described.
Do you think that will work?
Thanks, Pat.
It should work.
I did a sample config on a 2800
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
no snmp trap link-status
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip unnumbered GigabitEthernet0/1.10
GigabitEthernet0/1.10      172.16.0.209    YES manual up                    down
GigabitEthernet0/1.20      192.168.68.1    YES manual up                    down
GigabitEthernet0/1.30      172.16.0.209    YES TFTP   up                    down
This interface is not connect to anything and that is why it shows it as up and down, but you get the idea.
Reza
