IE 1000 switch in boot loop
irwinsnowbum
I have an 8 port IE 1000 that is stuck in a boot loop. Initially I accessed the device on 192.168.1.254/24 from the webpage 192.168.1.1 when that worked I accessed 192.168.1.254 via SSH and pushed a config in and did a reload.  Now the switch is stuck in a boot loop and goes from POST (SYS light Blank) to Exiting POST/Initializing  (Sys light Solid) to INIT done (SYS and Alarms LED are both green) however, it doesn't stya in the INIT done state long enough for me to depress the express setup switch for 15-20 seconds instead the switch cuts off and boots back into POST.  Any help would be appreciated.
Leo Laohoo
Console into the switch and reboot.
Post the entire boot-up process.
Unfortunately there is NO console port on these mini switches.  You have to hold the express setup button for 15-20 seconds then it defaults to 192.168.1.254/24 which you then web or ssh into.  It is a minimalist switch and several traditional Cisco command syntax didn't work.
