Network Switch Firmware
karimSherif35504
Community Member
Our case is that Cisco switches are installed in an offshore production system and upgrade of firmware will not be an easy task, so motivation is to upgrade switch firmware only incase there is urgent or critical improvements that current firmware version is missing.
What is your firmware upgrade recommendation for following switch model and firmware version.
1. Cisco Catalyst 3750-X
- 12.2(55)SE3
- 12.2(55)SE5
- 15.0(2)SE6
2. Cisco IE 3000
- 15.0(2)EY1
- 15.0(2)SE2
3. Cisco Catalyst 9300
- 16.6.2
Mark Elsen
 - Cisco offers so called gold-starred release(s) for a particular platform; if  you to cisco.com and subsequently software downloads , where you can then choose you particular platform and or switch to download software for. These releases are advisable for a particular train or global , if no specific train is has a gold-stared release and there is only one marked. If your devices are however functioning normal and no problems are seen , you should not upgrade.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
3750X = 15.2(4)E9
josef.kokal
Frequent Visitor
Frequent Visitor
For the C9000 you can go with 16.9.4 or 16.9.5
Both are fine
