@Stefan Mihajlov
- Switching capacity: minimum 4.8 Gbps
Not mentioned. They only state that the switch can be with 20 Gigabit Ethernet
- Minimum forwarding rate for 64-byte packets: 3.5 Mpps
Forwarding rate
Line rate for all ports and all packet sizes
- Support for a minimum of 4,000 VLAN IDs
256
- Flash memory: minimum 64 MB
4GB SD memory card for IE ( SD card is optional and is not shipped by default with the switch. )
Not mentioned on the Data Sheet
- Support for Ethernet ring
Delivers multiple rings, redundant ring topology for new network configurations
