IE 3000 Power supply alarm relay
Hi All,
In IE3000 Switch power supply alarm relay is reporting "ASSERT MAJOR Switch Redundant Pwr missing or failed"  when Power A or Power B down, Is it Normal ?
We are expect when Power A down should report MAJOR and Power B down should report MINOR.
Below is the configution output and logs
Switch#sh alarm settings
Alarm relay mode: Positive
Power Supply
         Alarm                   Enabled
         Relay                   MAJ, MIN
         Notifies                Enabled
         Syslog                  Enabled
Temperature-Primary
         Alarm                   Enabled
         Thresholds              MAX: 95C                MIN:  -20C
         Relay                   MAJ
         Notifies                Enabled
         Syslog                  Enabled
Temperature-Secondary
         Alarm                   Disabled
         Threshold
         Relay
         Notifies                Disabled
         Syslog                  Disabled
*Mar  1 00:13:27.722: %POWER_SUPPLIES-3-PWR_FAIL: Power supply A is not functioning
*Mar  1 00:13:27.722: %ENVIRONMENT-3-RPS_FAILED: ASSERT MAJOR Switch Redundant Pwr missing or failed
*Mar  1 00:13:59.280: %POWER_SUPPLIES-3-PWR_FAIL: Power supply B is not functioning
*Mar  1 00:13:59.280: %ENVIRONMENT-3-RPS_FAILED: ASSERT MAJOR Switch Redundant Pwr missing or failed
S.Rajkumar
0 Replies 0
