Nexus 2000 errors..
Muhammed AKYUZ
Level 4
Level 4
we get these logs from Nexus 2000. After reloadig this fex problem solved. What is the cause?
2012 Aug 22 09:54:04 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:04 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:05 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:05 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:05 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
s failure
2012 Aug 22 09:54:05 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_ENV_ERROR: FEX-106 Module 1 temperature sensor Outlet-1 failed.
2012 Aug 22 09:54:05 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_ENV_ERROR: FEX-106 Module 1 temperature sensor Outlet-2 failed.
2012 Aug 22 09:54:05 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_ENV_ERROR: FEX-106 Module 1 temperature sensor Inlet-1 failed.
2012 Aug 22 09:54:05 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_ENV_ERROR: FEX-106 Module 1 temperature sensor Die-1 failed.
2012 Aug 22 09:54:06 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:06 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:06 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:08 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:08 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:08 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:09 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:09 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:09 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:10 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:10 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:10 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:11 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:11 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:11 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:13 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:13 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:13 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:14 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:14 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:14 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:15 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:15 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:15 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:16 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:16 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:16 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:17 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:17 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:17 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:18 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:18 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:18 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:19 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:19 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:19 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:20 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:20 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:20 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:21 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:21 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:21 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:23 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:23 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:23 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:24 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:24 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:24 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:25 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:25 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:25 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:27 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:27 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:27 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:28 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:28 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:28 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:29 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:29 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:29 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:30 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:30 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:30 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:31 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:31 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:31 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:32 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:32 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:32 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:33 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
2012 Aug 22 09:54:33 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 1
2012 Aug 22 09:54:33 NX5500-TEST %SATCTRL-FEX106-4-SOHMS_PS_GPIO: FEX-106 System PS access failure on Power supply: 2
2012 Aug 22 09:54:35 NX5500-TEST %SATCTRL-FEX106-2-SOHMS_DIAG_ERROR: FEX-106 Module 1: Runtime diag detected major event: GPIO acces
s failure
Leo Laohoo
Power supplies not plugged in securely?
Muhammed AKYUZ
Level 4
Level 4
both of them plugged securely.
