IE-3300 NOT BOOTING
tomerb
I have ie-3300 new, and when I connect him to power supply and connect to him through console it like I'm in rommon mode but not rommon.
This is the only commands I have:
switch: ?
alias show / set alias(es)
boot boot image
cat display file content
copy copy a file
delete delete a file or directory
dir show filesystems or a directory of a filesystem
format format a filesystem
help show command help
history show command history
md5 compute md5 of a file
mkdir create a directory
rename rename a file or directory
reset reset system
set show / set environment variable(s)
sleep sleep for n milliseconds
unalias unset alias(es)
unset unset environment variable(s)
version show rommon version
and this is the when I resetting the switch:
switch: reset
Are you sure you want to reset the system (y/n)? y
Resetting...
Initializing disk drivers...
SD Card is not present
Initializing file systems...
* Rom Monitor for IE3x00 *
* Copyright (c) 2017-2021 by Cisco Systems, Inc. *
* All rights reserved. *
* Version: 7.1.14
* Compiled: Wed 20-Apr-22 22:19 [RELEASE SOFTWARE]
* Boot Partition: qspi-upgrade-bootloader
* Reset Reason: Soft Reset
When i connect USB to the SWITCH (4gb usb) he doesn't recognize him and when i try to connect to any port and load boot from tftp, the port wont come up and i dont see any link or something even the network card keep said the the cable is unconnected
23 Replies 23
Get into the switch> prompt
run the command  "dir flash" or dir bootflash or any other driver available. Use ? to figure this out
When you see the IOS file name, use the command
boot flash:<ios_fine_name>
This should be anough to get the switch back.
switch: dir ?
Error: Failed to list directory
switch: dir
List of filesystems currently registered:
crashinfo: 511.00MB EMMC - Crash info files
ucode0: 256.00MB EMMC - Microcode
emgy0: 256.00MB EMMC - Disaster Recovery
ucode1: 256.00MB EMMC - Microcode backup
emgy1: 256.00MB EMMC - Disaster Recovery backup
var: 8.00MB EMMC - ROMMON environment variables
lic0: 8.00MB EMMC - Licensing
lic1: 8.00MB EMMC - Licensing backup
obfl: 64.00MB EMMC - OBFL
flash: 1.61GB EMMC - flash file system
switch: dir flash:
Date Time Attribute Size Name
2023/04/26 01:37 drwxr-xr-x 4096 tracelogs
2023/04/26 06:53 drwxr-xr-x 4096 .installer
2023/04/26 03:13 drwxr-xr-x 4096 .rollback_timer
2023/04/26 03:13 drwxr-xr-x 4096 core
2023/04/26 03:13 drwxr-xr-x 4096 .ssh
2023/04/26 03:13 drwxrwxrwx 4096 .prst_sync
2023/04/26 03:13 drwxr-xr-x 4096 tech_support
2023/04/26 03:13 drwxrwxrwx 4096 gs_script
2023/04/26 06:53 drwxr-xr-x 4096 dc_profile_dir
2023/04/26 03:13 drwxr-xr-x 4096 EDScisco
2023/04/26 03:14 drwxr-xr-x 4096 pnp-info
2023/04/26 06:54 drwxr-xr-x 4096 ProfinetGSD
2023/04/26 03:13 drwxr-xr-x 4096 .USWAP
2023/04/26 03:13 drwxr-xr-x 4096 .CRFT
2023/04/26 06:56 drwxr-xr-x 4096 .dbpersist
2023/04/26 03:14 drwxr-xr-x 4096 onep
2023/04/26 06:56 -rw-r--r-- 46604 pnap.dat
2023/04/26 03:15 drwxr-xr-x 4096 managed
2023/04/26 06:56 -rw-r--r-- 33554432 nvram_config
2023/04/26 06:56 -rw-r--r-- 33554432 nvram_config_bkup
2023/04/26 03:15 drwxr-xr-x 4096 eem
2023/04/26 06:56 drwxr-xr-x 4096 pnp-tech
Total space = 1684480 KB
Available = 1583128 KB
switch:
I don't have any IOS name
Leo Laohoo
IF the switch is in ROMMON, post the complete output to the ROMMON command of "set".
switch: set
Environment variables in var:
BSI=0
ConfigReg=0x102
PN_SNMP_SYS_CONTACT=Switch
PN_SNMP_SYS_LOCATION=
PROFINET_CONN_PREV=0
PROFINET_DEVICE_NAME=
PROFINET_DEV_IM_DATE=
PROFINET_DEV_IM_DISC=
PROFINET_DEV_IM_FUNC=
PROFINET_DEV_IM_LOC=
RANDOM_NUM=815545287
RET_2_RCALTS=
Environment variables in sdflash:
Environment variables in qspiflash:
Environment variables in usbflash0:
Environment variables in usbflash1:
switch:
This is the Output
So someone has erased the firmware from the bootflash.
One of the ways to put the firmware back in is to put the BIN file into a USB flash drive and use the below ROMMON command:
emergency-install usbflash0:filename.bin
switch:
switch:
switch:
switch:
switch:
switch:
switch: emergency-install usbflash0:ie3x00-universalk9.17.09.03.SPA.bin
Error: command "emergency-install" not found
boot usbflash0:ie3x00-universalk9.17.09.03.SPA.bin
Once the switch has successfully boot, perform the Install Mode.
switch: boot usbflash0:ie3x00-universalk9.17.09.03.SPA.bin
Error: file "usbflash0:ie3x00-universalk9.17.09.03.SPA.bin" not found or already open
switch: dir usbflash0:
Error[22]: Failed to open directory
switch: dir usbflash1:
switch: boot usbflash1:ie3x00-universalk9.17.09.03.SPA.bin
Error: file "usbflash1:ie3x00-universalk9.17.09.03.SPA.bin" not found or already open
And normally the usb when is connected turn on red light - now, nothing.. both of the usb ports
Try a different USB flash drive.
I tried.
and the same usb work fine in other swtich
Not all USB thumb drives will work universally.
I have three different varieties of USB thumb drives on my desk.  Each one will NOT work in a specific Cisco product.
Ok,
I tried another 4GB usb, the same problem occur.
i tried to do it from tftp, but when i connect the pc to the switch port, nothing happened and even in the cli no port come up...
maybe this switch is broken?
tomerb
Any ideas?
The IE3300 has an SD Flash port.  Is there an SD Flash?
