IE 3300 Question
I am wondering if 2 of the IEM-3300-16T can go on an IE-3300? I have an application that needing about 40 ethernet cables into a rugged ethernet switch.
Thanks.
pieterh
look at the datasheet: Cisco Catalyst IE3300 Rugged Series Data Sheet - Cisco
  Expandable
◦    to up to 26 ports of GE by attaching one of 8 compatible modules (copper, PoE, fiber and 2.5G with IEEE® 802.3bt type 4 options)
◦    to up to 24 ports of GE plus 2 ports of 10G by attaching one of the 8 compatible modules (copper, PoE, fiber and 2.5G with IEEE® 802.3bt type 4 options)
-> not 2 expansion modules, not more than 26 ports.
your alternative is two switches connected together
additional info from  Cisco IE 3000 Series Switch Hardware Installation Guide
look at. Table 2-1 lists the supported port combinations of switch and expansion modules.
pieterh
  Expandable
