IE2000-16T67P-G-E Voltage Range without POE
PatrickBeck
I want to use the Switch IE2000-16T67P-G-E in a field installation without POE. Can this switch be operated with 24 V?
In the manual I am a bit curious about the models, so I am not quite sure if this is correct and the following sentence is for all IP67-Models.
Thank you for your help
with kind regards
Patrick
Reza Sharifi
If you are looking for a DC power supply, this is what is stated here:
See table-3 in this link;
https://www.router-switch.com/ie-2000-16t67p-g-e.html
PWR-IE160W-67-DC=
IP67-rated PoE DC-DC power supply, Input:18V-60V Output: 54V, 3.1A max 160W
Hi Reza Sharifi,
thank you for your answer. I am not directly looking for a DC power supply. The switch will be integrated in a machine installation. In the cabinet we have normally already a 24V DC power supply. The idea is to use this power supply directly with the switch, so i have not to use an extra 48V supply or the PWR-IE160W-67-DC=.
The only question is: Can the IE2000-16T67P-G-E be operated with 24V, when no POE is used as stated in the manual and is this also valid for my model (I have added the manual in the attachments (Page 24 and 42).
Thank you
with kind regards
Patrick
