IE3300 8U2X - Power Management Issue
Kurama312
Cisco Ethernet Switch - IE3300 (8U2X) with an Expansion Rack (IEM3300) with 16T / 16 ports
Power Supply: PWR-IE480W-PCAC-L= (Power Supply is providing 54V and Switch is receiving the same supply)
Under Power Management, Total Supported power is 125 Watts (This is the wattage I am hoping to increase)
Q1. I would like to if there is a way I can change the supported power to match that switch datasheet (which allows max of 480 W)
Q2. Why I am not able to see any ports from the expansion rack?
Your help on this matter will be highly appreciated. Thank you
balaji.bandi
Look at the datasheet :
mainly look :
Product specifications
Table 4.           IE3300 hardware specifications
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-ie3300-rugged-series/catalyst-ie3300-rugged-series-ds.html
BB
balaji.bandi
mainly look :
BB
