IE3X00 vs IE4000 switches DIN Rail kit compatibility
Ateeq Mohammed
Hi, Anyone please help me know same DIN Rail Kit used in IE4000 can be used in IE3300/3400 switches.
Also weather Expansion module also needed DIN Rail for mounting?
ammahend
if you have something like "Cisco STK-RACK-DINRAIL" 19" it would work for both IE3000 and IE4000.
You can install the switch as a standalone device on the DIN rail or with the expansion modules already connected. You must connect expansion modules to the switch before installing the switch on the DIN rail.
-hope this helps-
vishalbhandari
@Ateeq Mohammed
Yes, the same DIN Rail Kit used for the Cisco IE4000 can also be used for IE3300 and IE3400 switches.
For expansion modules, they do not require a separate DIN Rail kit as they attach to the main switch unit, which is already mounted on the rail.
BrianSekleckiGE
Does anyone know if the Cisco product rail depth is adjustable? A lot of the 3rd party products alternative to the Cisco Genunine STK-RACK-DINRAIL allow the depth to be adjusted.
