If Native vlan between Trunk ports not configured then what happens ?
lohit prasad
I have a network where Two trunk ports are allowed vlan 9  but no native vlan configured. will performance affects ?
2 Accepted Solutions
by default vlan1 is the native vlan to assign a different native vlan on the interface configure
 switchport trunk native vlan xxx
Richard
Deepak Kumar
Hi Lohit,
By default vlan 1 is native vlan and your configuration will never put effects on performance.
Deepak Kumaar
www.deepuverma.in
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Richard
You can't disable vlan1, but you can change it for native vlan (vlan1 for default)
You need vlan1 for protocols of comunication like CDP, STP, VTP,etc.
But native vlan send traffic without tag, like a acces port in a trunk port, all other send trought trunk port with tag
Deepak Kumar
Hi Lohit,
Deepak Kumaar
www.deepuverma.in
Deepak Kumar,
