If you default an interface, will all the sub-interfaces be removed as well?
praveenmathew27
Lets say I have the below config.
interface GigabitEthernet0/0/1
description test
encapsulation dot1Q 201
ip address x.x.x.x
no ip redirects
no ip proxy-arp
standby version 2
standby 201 ip y.y.y.y.y
standby 201 timers msec 500 2
standby 201 priority 200
standby 201 preempt delay minimum 270 reload 300
standby 201 track 1 decrement 150
interface GigabitEthernet0/0/1.200
description test2
encapsulation dot1Q 200
ip address x.x.x.y
no ip redirects
no ip proxy-arp
standby version 2
standby 200 ip y.y.y.y.x
standby 200 timers msec 500 2
standby 200 priority 150
standby 200 preempt
And another 3 sub-interfaces .212, .300, .400
If i do "default interface GigabitEthernet0/0/1" , will it remove the sub-interfaces as well?
Hello
No it will not remove the sub-interfaces it will just default the physical interface only to its default config, the same if you perform a default to a sub-interface, it will just default that specific sub-interface.
Kind Regards
Paul
luis_cordova
Thanks for the link, but just wanted to get confirmation, as this is on an ASR1001, running 15.4(1)S1 , using GigabitEthernet interface.
The provided link is very old and As of now, it should not impact on the subinterface if you do default the main interface. However, I would advise you contact with Cisco TAC to get the confirmation.
BR
Tayyab
*** Please rate all helpful responses and mark solutions***
Hello
Kind Regards
Paul
