IGMP snooping problems
David Kondicz
Hi all,
i am trying to filter IGMP on current ports. But if i show igmp snooping details in my catalyst 3560x it didnt show any igmp multicast address.
As source i have Cisco DCM connected to catalyst 3560x lab base port gi 0/48
I want to aply a filter for port gi 0/1 that can acces only to one multicast group 239.129.0.1
I have 10 multicast streams 239.129.0.1 - 239.129.0.10 but i dont understand why it is not working. mrouter port is setet up for gi 0/48
Thank you
BR
dave
5 Replies 5
smehrnia
Level 7
Level 7
hi,
for controlling multicast traffic flow for switch interfaces, you have to create an IGMP profiles, like access lists, permit or deny multicast routes in it and then assign it to the desired interface. in your case:
(config)# ip igmp profile 2
(config-igmp-profile)# permit
(config-igmp-profile)# range 239.129.0.1
(config-igmp-profile)# end
int gi0/1
ip igmp filter 2
end
plz Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
Hello Soroush,
i used this config as my first step but not working
dave
I fixed this with MVR settings, but still cant see anything in IGMP
Solved!
Just need to enable queuer
ip igmp snooping queuer
ip igmp snooping queuer address 192.0.2.1
Queuer or Querier? could u share your reference plz?
Soroush.
Hope it Helps!
Soroush.
