%ILPOWER-3-CONTROLLER_ERR: Controller error
admin_2
Level 7
Level 7
would anyone be able in assist in explaining the possible causes of the syslog messages generated by my 3560 switch below. At present no IP phones have been attached to the switch.
Switch_3560# show log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: disabled
Monitor logging: level debugging, 13 messages logged, xml disabled,
filtering disabled
Logging to: vty1(13)
Buffer logging: level debugging, 7285 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Trap logging: level informational, 7287 message lines logged
Logging to 62.187.174.213, 7287 message lines logged, xml disabled,
filtering disabled
Logging to 158.98.128.134, 7287 message lines logged, xml disabled,
filtering disabled
Log Buffer (50000 bytes):
Nov 20 02:52:21: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 3: accessing failed
Nov 20 02:53:21: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 3: accessing failed
Nov 20 02:54:21: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 3: accessing failed
Nov 20 02:55:21: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 3: accessing failed
Nov 20 02:56:21: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 3: accessing failed
Nov 20 02:57:21: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 3: accessing failed
Switch_3560#show version
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(25)SEB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 08-Jun-05 03:58 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEA, RELEASE SOFTWARE (fc)
ltsgb3199-gba-lanua01 uptime is 14 weeks, 3 days, 21 hours, 17 minutes
System restarted at 14:53:51 BST Thu Aug 10 2006
System image file is "flash:c3560-ipservicesk9-mz.122-25.SEB2.bin"
cisco WS-C3560-48PS (PowerPC405) processor (revision M0) with 118784K/12280K bytes of memory.
Processor board ID CAT0938Z2Q4
Last reset from power-on
4 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560-48PS 12.2(25)SEB2 C3560-IPSERVICESK9-M
Many thanks
Sanjay
sourabhagarwal
Level 9
Level 9
here is the explanation of the errors coming in your log.
%ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number [dec]: [chars.]
Explanation: This message means that an error reported or caused by the PoE controller
was detected. [chars] is the controller number. When a Cisco catalyst interface
receives an Electrostatic Discharge (ESD) for example, from a powered IP Phone,
some interfaces go down and no longer provide power.
Recommended Action: Issue shutdown and then no shutdown interface configuration
mode command on the affected interfaces. IOS version 12.1(14)EA1, or later, provides
an ESD recovering mechanism. Make sure the loaded IOS image is not affected by
Bug CSCea40671 and CSCeb24148. If the image is affected by the bug, consider
loading to IOS 12.1(14)EA1 or later.
