VLAN problem in CISCO 2811 Router
redwan_ahmed
I am facing serious problem with my 2811 router.
I have install a one 4ESW (HWIC)card.
All of these ports are under VALN 1.
Then I have just configured 4 VLANS in here.
Like :
FastEthernet0/0/0 as VLAN 1 (IP ADDRESS : 192.168.80.1/29)
FastEthernet0/0/1 as VLAN 2 (IP ADDRESS : 192.168.80.9/29)
FastEthernet0/0/2 as VLAN 3 (IP ADDRESS : 192.168.80.17/29)
FastEthernet0/0/3 as VLAN 4 (IP ADDRESS : 192.168.80.25/29)
Well this is working fine.
Now I have just install a new 4ESW (HWIC) card, in slot 1. ports are like that.
FastEthernet0/1/0 , FastEthernet0/1/1 , FastEthernet0/1/2 , FastEthernet0/1/3.
Those ports are also in VLAN 1.
Now I have just configured those new ports as separate VLANS. Like
FastEthernet0/1/0 as VLAN 5 (IP ADDRESS : 192.168.80.33/29)
FastEthernet0/1/1 as VLAN 6 (IP ADDRESS : 192.168.80.41/29)
FastEthernet0/1/2 as VLAN 7 (IP ADDRESS : 192.168.80.49/29)
FastEthernet0/1/3 as VLAN 8 (IP ADDRESS : 192.168.80.57/29)
Well this VLANS are not working. Even the ports are UP. So how could I resolve this problem? Is their any logical problem.
6 Replies 6
make sure you have both switch modules configured in stacked mode. Check this link for configuration details:
Configuring Stacking
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802c6bb6.html#wp1049119
HTH,
GP
glen.grant
Did you create the new vlans in the vlan database ? You would have to post the configs along with a show vlan commmand . There is not too much to it , create the layer 2 vlans in the vlan database then create the layer 3 SVI's for the layer 3 end of it .
minumathur
Please send configuration and show vlan breif.
-Minu
Rashed#SHow vlan-switch
VLAN Name Status Ports
1 default active Fa0/0/0
2 VLAN0002 active Fa0/0/1
3 VLAN0003 active Fa0/0/2
4 VLAN0004 active Fa0/0/3
5 VLAN0005 active Fa0/1/0
6 VLAN0006 active Fa0/1/1
7 VLAN0007 active Fa0/1/2
8 VLAN0008 active Fa0/1/3
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 1002 1003
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
4 enet 100004 1500 - - - - - 0 0
5 enet 100005 1500 - - - - - 0 0
6 enet 100006 1500 - - - - - 0 0
7 enet 100007 1500 - - - - - 0 0
8 enet 100008 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 1 1003
1003 tr 101003 1500 1005 0 - - srb 1 1002
1004 fdnet 101004 1500 - - 1 ibm - 0 0
1005 trnet 101005 1500 - - 1 ibm - 0 0
Rashed#
Rashed#show ip interface brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 10.11.12.1 YES NVRAM up down
FastEthernet0/1 unassigned YES NVRAM up down
FastEthernet0/0/0 unassigned YES unset down down
FastEthernet0/0/1 unassigned YES unset down down
FastEthernet0/0/2 unassigned YES unset down down
FastEthernet0/0/3 unassigned YES unset down down
FastEthernet0/1/0 unassigned YES unset up up
FastEthernet0/1/1 unassigned YES unset down down
FastEthernet0/1/2 unassigned YES unset up down
FastEthernet0/1/3 unassigned YES unset up down
Vlan1 192.168.80.1 YES manual up down
Vlan2 192.168.80.9 YES manual up down
Vlan3 192.168.80.17 YES manual up down
Vlan4 192.168.80.25 YES manual up down
Vlan5 192.168.80.33 YES manual up up
Vlan6 192.168.80.41 YES manual up down
Vlan7 192.168.80.49 YES manual up down
Vlan8 192.168.80.57 YES manual up down
Rashed# sh run
Building configuration...
Current configuration : 2170 bytes
version 12.4
service timestamps log datetime localtime
service password-encryption
interface FastEthernet0/0
ip address 10.11.12.1 255.255.255.252
duplex full
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
switchport access vlan 2
interface FastEthernet0/0/2
switchport access vlan 3
interface FastEthernet0/0/3
switchport access vlan 4
interface FastEthernet0/1/0
switchport access vlan 5
interface FastEthernet0/1/1
switchport access vlan 6
interface FastEthernet0/1/2
switchport access vlan 7
interface FastEthernet0/1/3
switchport access vlan 8
interface Vlan1
ip address 192.168.80.1 255.255.255.248
interface Vlan2
ip address 192.168.80.9 255.255.255.248
interface Vlan3
ip address 192.168.80.17 255.255.255.248
interface Vlan4
ip address 192.168.80.25 255.255.255.248
interface Vlan5
ip address 192.168.80.33 255.255.255.248
interface Vlan6
ip address 192.168.80.41 255.255.255.248
interface Vlan7
ip address 192.168.80.49 255.255.255.248
interface Vlan8
ip address 192.168.80.57 255.255.255.248
fundataca
Just to let you know I am in the same boat.
Cisco is looking at my config right know and when I get answers I will post for you.
