01-31-2022 03:05 PM
Hello Cisco Community,
We've been seeing the following error every so often:
Oct 23 06:23:58.971 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 2: has been reset unexpectedly or s2w bus err Oct 28 13:36:36.009 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 2: has been reset unexpectedly or s2w bus err Oct 31 02:48:18.923 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 1: has been reset unexpectedly or s2w bus err Oct 31 22:19:52.117 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 2: has been reset unexpectedly or s2w bus err Nov 5 16:35:07.319 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 0: has been reset unexpectedly or s2w bus err Nov 18 15:01:53.810 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 0: has been reset unexpectedly or s2w bus err Nov 24 18:09:07.604 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 1: has been reset unexpectedly or s2w bus err Nov 27 18:36:08.988 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 1: has been reset unexpectedly or s2w bus err Nov 30 15:01:06.314 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 2: has been reset unexpectedly or s2w bus err Dec 1 19:03:53.485 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 0: has been reset unexpectedly or s2w bus err Dec 2 20:53:36.458 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 2: has been reset unexpectedly or s2w bus err Dec 7 06:23:32.884 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 0: has been reset unexpectedly or s2w bus err Jan 1 01:56:19.468 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 1: has been reset unexpectedly or s2w bus err Jan 1 06:46:27.671 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 2: has been reset unexpectedly or s2w bus err Jan 22 23:05:07.138 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 1: has been reset unexpectedly or s2w bus err Jan 23 17:43:41.913 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 1: has been reset unexpectedly or s2w bus err Jan 31 00:32:36.090 MST: %ILPOWER-3-CONTROLLER_ERR: Controller error, Controller number 2: has been reset unexpectedly or s2w bus err
The above is for a fairly new IE4010 deployed:
IE4010 Boot Loader (IE4010-HBOOT-M) Version 15.2(4r)EC, RELEASE SOFTWARE (fc1) xxxxxxxxxnsw02 uptime is 14 weeks, 5 days, 9 hours, 20 minutes System restarted at 06:26:54 MST Wed Oct 20 2021 System image file is "sdflash:/ie4010-universalk9-mz.152-7.E2/ie4010-universalk9-mz.152-7.E2.bin"
I did a search and found a couple of references about possible old code bug but it is unrelated to this model. There was also a forum posting that talked about incorrect grounding. Just wanted to reach out and see if anyone has seen this before and could point me in the right direction. I don't have a TAC account so unable to open a case with Cisco.
Thanks in advance.
-E
01-31-2022 03:12 PM
I am currently using 15.2(7)E5 and I do not see this issue.
I recommend upgrading that IOS and see if it makes any improvements.
01-31-2022 03:56 PM
yes, this was encountered in other devices which do not proper grounding, change the source of power and reboot device, and observe, still has an issue, as suggested uplift the IOS and test.
02-01-2022 07:24 AM
Thanks for taking the time to respond. I'll look for an opportunity to proceed with the suggestions and report back the results.
02-18-2025 05:28 AM
Any updates on this issue? I have the same problem with an IE-4010 running the recommended version. Can we confirm that it is due to improper grounding, or could it be caused by a malfunction in power supplies PS0 or PS1?
