10-05-2016 03:22 AM - edited 03-08-2019 07:41 AM
HI,
I have a problem with a switch Cisco 2960X, It there's an error in the log on an interface, what bothers me and I do not have any device to connect it.
Here is the run sho interface and the log message :
My software version is : 15.2(2)E4
Oct 4 22:30:51: %ILPOWER-7-DETECT: Interface Gi1/0/11: Power Device detected: IEEE PD
Oct 4 22:31:21: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/11: Power given, but Power Controller does not report Power Good
interface GigabitEthernet1/0/11
switchport
switchport access vlan 11
switchport private-vlan trunk encapsulation dot1q
switchport private-vlan trunk native vlan tag
switchport mode access
switchport nonegotiate
no switchport protected
no switchport block multicast
no switchport block unicast
switchport port-security maximum 65535 vlan voice
no switchport port-security mac-address sticky
no ip arp inspection trust
ip arp inspection limit rate 15 burst interval 1
no logging event link-status
load-interval 300
carrier-delay 2
no shutdown
tx-ring-limit 0
tx-queue-limit 0
power inline auto max 30000
power inline static
power inline never
power inline police
ipv6 mld snooping tcn flood
snmp trap mac-notification change added
snmp trap mac-notification change removed
no snmp trap link-status
mls qos cos 0
no cdp enable
arp arpa
arp timeout 14400
spanning-tree portfast disable
spanning-tree portfast trunk
spanning-tree bpduguard enable
spanning-tree port-priority 128
spanning-tree cost 0
hold-queue 75 in
hold-queue 40 out
ip igmp snooping tcn flood
Thank you for your HEL
10-05-2016 03:31 AM
Could be an IOS bug.
10-05-2016 03:54 AM
you have known the note cisco about this bug ?
thank for you reply
10-05-2016 03:57 AM
No.
I have several 2960X running the exact IOS with phones and APs on them. I don't have error messages like that.
But then again, I don't have some crazed configuration like that on my trunk ports either.
10-05-2016 04:02 AM
One can like you I have 40 this switch with IOS and I encounter this problem on a single knowing I do not have any device requiring POE, strange I'll open a case Cisco.
Thank for your feddback 🙂
11-22-2016 09:48 PM
Hi bochi75017,
Did you managed to open a TAC case for this? I do have the same issue using the same switches. The device connected to the port that has an error is a laptop with a docking station.
08-26-2019 08:35 PM
Hi ,
I also got the same error message of 2960X with Version 15.2(2)E6, but can not find any bug related.
Is there anyone know how to fix this issue? reload switch?
