ILPOWER-3 Issue
Shawn Williams
We recently installed 3 2980X switches in a stack and now only after about 2 months we are getting reports of network disconnects.  After researching we are seeing the following errors in the log on a handful of ports.
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/9: Power Controller reports power supply VEE under voltage and lockout
IOS Version 15.2(2)E4
These ports do not currently have POE devices plugged into them but each time the error occurs the port drops and the individuals lose network.
Mark Malone
Could be a software bug for POE
quick fix maybe to turn off the poe on one of the ports your having an issue with and see if it stops the problem
interface x/x
no power inline
or
power inline never
the syntax varies from device to device
