iMac
anitachoi3
Level 6
Level 6
I setup two macintosh in two VLANs, one is 192.168.1.106/24 other is 192.168.16.20/24 segment. I find that they cannot browse to each other. If I put the MAC into the same segment (e.g. 192.168.1.0/24). they can browse each other. My router is 4700. how do I config router so that both MAc can communication to ech other?
Rdgs
owillins
Level 11
Level 11
Could you paste your show running config and show tech?
the router config and MAC setup. I am not MAC expert. the issue is related to the config of apple talk and MAC PC. I do not have the idea of the setting "69-70 69.22". such copy from the sample config of cisco web site.
R1
ip subnet-zero
no ip domain-lookup
ip cef
appletalk routing
interface Loopback0
ip address 192.168.254.3 255.255.255.255
interface FastEthernet0
description 192.168.1.0/24
encapsulation dot1Q 2
ip helper-address 192.168.0.10
appletalk cable-range 69-70 69.22
interface FastEthernet1
description 192.168.16.0/24
encapsulation dot1Q 15
ip address 192.168.16.1 255.255.255.0
appletalk cable-range 69-70 69.152
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.254
MAC A
ip 192.168.1.106 255.255.255.0
apple talk
mannual config:
field 1: 69
field 2: 69
MAC B
ip 192.168.16.20 255.255.255.0
apple talk
mannual config:
field 1: 69
field 2: 70
