Image install Problem
Patrick McHenry
Level 4
Level 4
I want to copy a file from one ASR1001 and copy it to another. I ntried using tftp 32 but this is not going to work as the image is 315 MB.
Can someone please give me directions on how to copy an image from one router directly to another router's flash, if possible?
Thanks, Pat.
5 Replies 5
Leo Laohoo
I have a pair of ASR1002 in two locations and I've pumped the IOS from my PC using TFTPd32/TFTPd64 and I don't have a problem.
And I've done this very, very regularly.
So, I should be able to download and uplaod an image this size using tftp32? I just tried and it keeps failing.My firewall is off on my PC. If I am reading this correctly, the image is 315MB. Is that correct?
AP-1001-VPN#sh flash
-#- --length-- ---------date/time--------- path
  1       4096 Jun 14 2012 08:51:46 +00:00 /bootflash/
  2      16384 Aug 16 2011 07:16:49 +00:00 /bootflash/lost+found
  3  315449448 Aug 16 2011 07:18:17 +00:00 /bootflash/asr1001-universalk9.03.03.00.S.151-2.S.bin
  4       4096 Aug 16 2011 07:19:53 +00:00 /bootflash/.installer
  5       4096 Aug 16 2011 07:46:57 +00:00 /bootflash/core
  6       4096 Dec 05 2011 10:01:31 +00:00 /bootflash/.prst_sync
AP-1001-VPN#copy flash tftp
Source filename [asr1001-universalk9.03.03.00.S.151-2.S.bin]?
Address or name of remote host []? 172.20.22.141
Destination filename [asr1001-universalk9.03.03.00.S.151-2.S.bin]?
%Error opening tftp://172.20.22.141/asr1001-universalk9.03.03.00.S.151-2.S.bin (Timed out)
AP-1001-VPN#
Then I changed the tftp source to a different interface on the router and I actually got some messages from the tftp server log. So, it was trying to hit the tftp server for sure.
Connection received from 172.20.1.131 on port 58207 [14/06 09:17:58.821]
Write request for file . Mode octet [14/06 09:17:58.822]
Using local port 60032 [14/06 09:17:58.825]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:17:59.847]
Connection received from 172.20.1.131 on port 58207 [14/06 09:18:02.814]
Write request for file . Mode octet [14/06 09:18:02.814]
Using local port 60033 [14/06 09:18:02.815]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:18:03.816]
Connection received from 172.20.1.131 on port 58207 [14/06 09:18:07.814]
Write request for file . Mode octet [14/06 09:18:07.814]
Using local port 60034 [14/06 09:18:07.815]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:18:08.816]
Connection received from 172.20.1.131 on port 58207 [14/06 09:18:13.824]
Write request for file . Mode octet [14/06 09:18:13.825]
Using local port 60035 [14/06 09:18:13.825]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:18:14.826]
Connection received from 172.20.1.131 on port 58207 [14/06 09:18:20.824]
Write request for file . Mode octet [14/06 09:18:20.824]
Using local port 60036 [14/06 09:18:20.825]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:18:21.826]
Connection received from 172.20.1.131 on port 61223 [14/06 09:20:33.865]
Write request for file . Mode octet [14/06 09:20:33.866]
Using local port 60037 [14/06 09:20:33.866]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:20:34.871]
Connection received from 172.20.1.131 on port 61223 [14/06 09:20:37.864]
Write request for file . Mode octet [14/06 09:20:37.867]
Using local port 60038 [14/06 09:20:37.867]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:20:38.872]
Connection received from 172.20.1.131 on port 61223 [14/06 09:20:42.865]
Write request for file . Mode octet [14/06 09:20:42.865]
Using local port 60039 [14/06 09:20:42.866]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:20:43.872]
Connection received from 172.20.1.131 on port 61223 [14/06 09:20:48.865]
Write request for file . Mode octet [14/06 09:20:48.868]
Using local port 60040 [14/06 09:20:48.868]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:20:49.873]
Connection received from 172.20.1.131 on port 61223 [14/06 09:20:55.865]
Write request for file . Mode octet [14/06 09:20:55.866]
Using local port 60041 [14/06 09:20:55.866]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:20:56.874]
Connection received from 172.20.1.131 on port 59395 [14/06 09:22:02.503]
Write request for file . Mode octet [14/06 09:22:02.509]
Using local port 63139 [14/06 09:22:02.517]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:22:03.519]
Connection received from 172.20.1.131 on port 59395 [14/06 09:22:06.502]
Write request for file . Mode octet [14/06 09:22:06.503]
Using local port 63140 [14/06 09:22:06.503]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:22:07.515]
Connection received from 172.20.1.131 on port 59395 [14/06 09:22:11.503]
Write request for file . Mode octet [14/06 09:22:11.504]
Using local port 63141 [14/06 09:22:11.504]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:22:12.514]
Connection received from 172.20.1.131 on port 59395 [14/06 09:22:17.503]
Write request for file . Mode octet [14/06 09:22:17.503]
Using local port 63142 [14/06 09:22:17.504]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:22:18.504]
Connection received from 172.20.1.131 on port 59395 [14/06 09:22:24.503]
Write request for file . Mode octet [14/06 09:22:24.504]
Using local port 64236 [14/06 09:22:24.504]
: rcvd 0 blk, 0 bytes in 1 s. 0 blk resent [14/06 09:22:25.505]
AP-1001-VPN#
Thanks, Pat.
Hi Patrick,
Something is blocking this or could be an application conflict.
Here are two more options for you to try:
1.  Use a different TFTP software that will support that file size such as SolarWinds' Free TFTP Server.
2.  If you are close to the appliance, then you can use USB to transfer the file to the one physically closest to you and TFTP-transfer to the furthest one.
Hieu Cao
Level 4
Level 4
I've not done direct router-to-router transfer, but you can FTP the file from one router's flash to your computer, then FTP it to another router.
Downloaded filezilla and it worked great.
Thanks, Pat
