Implementing QoS on 3750 using MQC
Paul_Yarwood
Hi all,
I'm attempting to configure Classification and Marking on our access switches using the MQC model. The Switches are 3750's running IPBase Version 12.2(35)SE. For some reason when I activate the policy-map on an interface, no traffic is being tagged, i've used the 3750 QoS configuration examples (
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a0080883f9e.shtml) for reference and can't see where I'm going wrong, wondered if anyone can see where I've gone awry?
The requirement at the moment is just to mark Citrix Packets as AF31 (no policing is required at this point). I've copied the relevant bits of the config below (Sensitive data removed):
mls qos
ip access-list extended CITRIX_NACL
permit tcp any any eq 2598
permit tcp any any eq 1494
class-map match-any MATCH_AF31
  match access-group name CITRIX_NACL
policy-map MARK_TRAFFIC
  class MATCH_AF31
   set dscp af31
interface FastEthernet2/0/1
description TestPort_PC
switchport access vlan 10
switchport mode access
service-policy input MARK_TRAFFIC
That port has a PC plugged into it, which is accessing Citrix and running a continual ping to a device on another subnet. The output from a show policy-map int FA2/0/1 is below:
sh policy-map int fa2/0/1
FastEthernet2/0/1
  Service-policy input: MARK_TRAFFIC
    Class-map: MATCH_AF31 (match-any)
      0 packets, 0 bytes
       offered rate 0 bps, drop rate 0 bps
      Match: access-group name CITRIX_NACL
        0 packets, 0 bytes
         rate 0 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
         rate 0 bps
As you can see no traffic is marked as AF31, but also no traffic is shown in the default-class either suggesting it's probably not just that I've put a typo in the ACL. An upstream packet capture shows that the packets are definately not being tagged.
Can anyone see where I've messed up?
Paul
rsimoni
Hi Paul,
2 quick comments:
1. Can you check if you have "no mls qos rewrite ip dscp"  in your config? If yes can you remove it (mls qos rewrite ip dscp ).
2. From interface notation I see that you have switches in a stack. Is switch 2 a slave switch by any chance? if yes can you try the same config on the master switch instead?
Riccardo
5 Replies 5
cadet alain
even if you can type this command it won't give you any useful information as the interface command is not supported.
you should use sh mls qos interface f2/0/1 statistics instead
Regards.
Alain
Alain,
Thanks for that, hadnt realised it was unsupported as it just takes the command without complaint.
rsimoni
Hi Paul,
2 quick comments:
Riccardo
Riccardo,
Step one got it thanks very much!
For reference was configuring via Telnet, so I assume it probably uses the stack master to process the vty line input, just guessing though don't have any evidence to back that up, worked happily enough in any event.
I am glad to read
the command you had in the config, as you would have certanly understood by now, was disabling the capability to write the dscp field.
Riccardo
