02-15-2012 09:29 AM - edited 03-07-2019 04:57 AM
hi! I've the setup as per the diagram attached. I try to setup w ccp in our env. I noticed that the wccp command will only work on the interface level if i turn the switch port into no switchport. Here are the draft of the command. The objective is to enable internet traffic to flow through the proxy.
For the port that has been turned to no switchport, what additional thing that need to be done there? (do i need to configure ip in the no switchport's ports and do internal routing)Do i need to configure anything in the port connected to the wlc? Pls let me know anything has been missed out. Thx.
Additional Info,
-this is a isolated network from the corporate lan.
-the dhcp ip assignment is from the fw.
-this network segment is in vlan 111 as a vrf network.
-the proxy is a linux appliance on esx vm.
ip wccp web-cache
access-list 10 permit host 192.168.1.2
ip wccp web-cache group-list 10
ip wccp web-cache redirect-list 10
interface gi 0/3
ip wccp web-cache redirect in
interface gi 0/2
ip wccp web-cache redirect out
02-15-2012 11:44 AM
There is nothing wrong with the switch not taking the WCCP commands if the "no switchport" command is not used. WCCP operates at layer 3 and the no switchport commands moves your interface from a L2 to L3 interface where you can do the L3 address assignment.
One thing I want to know is your objective here. Do you want all your internal http traffic to go out via the proxy?
I would redirect all the http traffic from vlan111 in that case:
interface Vlan111
ip address x.x.x.x x.x.x.x
02-15-2012 11:54 AM
One more thing after a second thought...
ip wccp web-cache redirect-list webcache_HTTP_traffic
ip access-list extended Webcache_HTTP_traffic
remark ACL used for WCCP re-direct list
permit tcp any any eq www
remark Allow IP traffic
permit ip any any
On the web-cache appliance you have to enable WCCP and configure it to listen to the router ip address to associate, so that it can establish the WCCP partnership...
02-16-2012 09:41 AM
hi! If i understand you correctly, you are saying
1) If i want all the internet traffic to go through the proxy, i only need to configure wccp in the vlan interface, not in the physical port? I checked that the vlan interface of my L3 siwtch only has the command "ip wccp web-cache redirect out" but not "in". Is that how it shd be?
2) What if i want to set it on the physical port, the port has to be a L3 port? I will need to put in IP addresses in that same range eg gi0/2 (192.168.1.10) and gi0/3(192.168.1.11)?
3) The command you stated below, is it applied in the global mode or interface level? The switch doesn't support redirect-list in global mode.
"ip wccp web-cache redirect-list webcache_HTTP_traffic "
Thx
02-16-2012 10:26 AM
What kind of switch do you have ?
02-16-2012 10:48 AM
My experience it is much better to configure the whole vlan than the interface and this is how I have been doing it and has worked for me.
Is ip routing enabled ?
this is what I just tried on a 3560 switch:
Global command
ip wccp web-cache redirect-list Webcache_HTTP_traffic
permit ip any any
interface Vlanx <<<--- change to your vlan id
ip address 10.x.x.x 255.255.255.0
end
My mistake on the redirect, should be in not out.....
I am sure this will work.
__________________
Please rate if this helped you.
02-16-2012 07:04 PM
hi! I'm using cat4506 with (cat 4500-ENTSERVICESK9- M), Version 12. 2(52).
Here are the options available.
(config)#ip wccp web-cache re
(config)#ip wccp web-cache ?
accelerated Enable hardware acceleration
group-address Set the multicast group
group-list Set the access-list used to permit group membership
password Authentication password (key)
I don't think i've the remark command in Global as well.
02-16-2012 11:58 PM
Could you try:
ip wccp web-cache
at the end of it all, you will see in the config :
Usually on the extended access list you have the remark option, if it does not work then apply only the necessary config:
permit ip any any
Hope this helps...
