Implementing Voice VLAN with SG300.
greg.kujawa
So I have native VLAN 1 for the client/server data hosts. And want to implement VLAN 11 for Polycom IP phones. I have a test lab with an SG300 and it's working fine. All computers that patch into the Polycoms are members of VLAN 1 and the phones themselves are members of VLAN 11.
Taking the SG300 config and applying it to a production SG300 with the same Polycom IP phone models, the results aren't the same. Looking at the MAC dynamic table on the SG300, I can see the phones are listed as being both on VLAN 1 and VLAN 11. The VLAN 11's DHCP server has assigned IP addresses to them. But they aren't routable to try to ping as a result of the "dual membership."
I've looked in the web GUI as well as the CLI config files. They look identical in terms of the Voice VLAN config. I'll paste them below. Any suggestions would be appreciated!
The working SG300:
config-file-header
switchd12afb
v1.3.5.58 / R750_NIK_1_35_647_358
CLI v1.0
set system mode switch
file SSD indicator plaintext
vlan database
vlan 11
exit
voice vlan id 11
voice vlan state auto-enabled
voice vlan cos 5
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 0004f2 Polycom_SP_Phone__
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname switchd12afb
username cisco password encrypted bb49db151a5719e3ba5c7a1e26bf9e4ecd516ca3 privilege 15
ip ssh server
ip ssh password-auth
clock timezone " " -5
clock summer-time web recurring usa
clock source sntp
sntp unicast client enable
sntp unicast client poll
sntp server 10.0.0.74
interface vlan 1
 ip address 10.0.5.254 255.255.255.0
 no ip address dhcp
interface vlan 11
 name voip
interface gigabitethernet1
 switchport trunk allowed vlan add 11
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet25
interface gigabitethernet26
interface gigabitethernet27
interface gigabitethernet28
exit
macro auto disabled
ip default-gateway 10.0.5.1
ip ssh-client key rsa key-pair
And the "bad" SG300.
config-file-header
switchee5fc3
v1.4.2.4 / R800_NIK_1_4_194_194
CLI v1.0
vlan database
vlan 11
exit
voice vlan id 11
voice vlan cos 5
voice vlan oui-table add 0004f2 Polycom_SP_phone
hostname switchee5fc3
management access-list All-Access
permit
exit
management access-class All-Access
logging host 10.0.2.5 facility local0 severity warnings
username cisco password encrypted 7f8feb06a0097899eb262842bad9d1615cd2df7d privilege 15
ip ssh server
snmp-server location "Short North"
snmp-server contact "Greg Kujawa"
clock source sntp
clock source browser
sntp server 10.0.2.5 poll
clock dhcp timezone
interface vlan 1
 ip address 10.0.2.254 255.255.255.0
 no ip address dhcp
interface vlan 11
 name Voip
exit
macro auto disabled
ip default-gateway 10.0.2.1
The only real difference I see is the software version running on the SG300's. The working config is an older version. I wouldn't think this has anything to do with the issue though.
greg.kujawa
I did see mention of some Voice VLAN bugs in newer Cisco Sx300 software versions --> https://community.cisco.com/t5/small-business-switches/sg300-general-mode-with-voice-vlan-problem-after-ios-upgrade/td-p/2665283#comment-10277306. That's about the only thing I can think of. Since I have looked side-by-side at the working config and the non-working config. And the Voice VLAN setups are the same. So that's about the only thing I can think of...
If there are any Cisco employees online reading this, does anyone know what version fixed the Voice VLAN issues? The latest version I see available for download is 1.4.10.6. I'd rather upgrade than downgrade the firmware image really. Plus, if I update the version either way, do I need to totally factory reset the switch and reconfigure from scratch?
