In core switch 4507 ip base licences in eigrp it is showing eigrp stub connected static summary redistributed
In our one project there is one Core switch 4507 and 9 Distribution are connected with single mode fiber.
when i configure the eigrp on both Core and Distribution switch in the eigrp configuration .
 router eigrp 2318
 network 10.241.1.4 0.0.0.3
 redistribute connected
The show running of Eigrp in core switch.
router eigrp 2318
network 10.241.1.8 0.0.0.3
network 10.241.1.12 0.0.0.3
network 10.241.1.16 0.0.0.3
network 10.241.1.20 0.0.0.3
network 10.241.1.24 0.0.0.3
network 10.241.1.28 0.0.0.3
network 10.241.1.32 0.0.0.3
network 10.241.1.36 0.0.0.3
redistribute static
I do not need eigrp stub connected static summary redistributed
The ios running in core switch is ip base shell i need to up upgrade  the ios to Advanced Enterprise Services
to remove eigrp stub connected static summary redistributed.
The out of core switch of show version is shown below
Main-Coreswitch#sh ver
Main-Coreswitch#sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.03.01.XO RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 30-Apr-14 02:55 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.1(1r)SG4
Main-Coreswitch uptime is 4 days, 20 hours, 52 minutes
Uptime for this control processor is 4 days, 20 hours, 54 minutes
Running default software
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1449
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP8-E'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4507R+E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID FXS1828Q064
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from PowerUp
1 Virtual Ethernet interface
72 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
router eigrp 2318
redistribute static
ip forward-protocol nd
no ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 Null0
access-list 5 permit 10.231.83.15
The out of Distribution switch of show version is shown below
CLASS-A-Distribution#sh version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9NPE-M), Version 15.0(2)SE6, RELEASE SOFTWARE (fc2)
Compiled Wed 09-Apr-14 02:59 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
CLASS-A-Distribution uptime is 4 days, 21 hours, 3 minutes
System restarted at 01:27:31 UTC Wed Mar 30 2011
System image file is "flash:/c3750e-universalk9npe-mz.150-2.SE6/c3750e-universalk9npe-mz.150-2.SE6.bin"
export@cisco.com.
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-12S (PowerPC405) processor (revision N0) with 524288K bytes of memory.
Processor board ID FDO1825R0C3
Last reset from power-on
8 Virtual Ethernet interfaces
1 FastEthernet interface
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 1C:6A:7A:D3:11:00
Motherboard assembly number : 73-13329-06
Motherboard serial number : FDO18250A5L
Model revision number : N0
Motherboard revision number : A0
Model number : WS-C3750X-12S-S
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FDO18250MH2
System serial number : FDO1825R0C3
Top Assembly Part Number : 800-35090-06
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : CMMPL00DRA
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 18 WS-C3750X-12S 15.0(2)SE6 C3750E-UNIVERSALK9NPE-M
Configuration register is 0xF
router eigrp 2318
shillings
Level 4
Level 4
Full EIGRP routing on the core will require the Enterprise Services feature set:
IOS XE 3.3 Release Notes
Same still applies to the latest IOS-XE 3.8 and IOS 15.2 releases.
