Inbound Qos on 6509 not working
Nick Cutting
6509 - Not working
1    6  Firewall Module
2    8  Intrusion Detection System
3    1  Application Control Engine Module
4   16  CEF720 16 port 10GE
5    2  Supervisor Engine 720 (Active)
6   16  CEF720 16 port 10GE
7   48  CEF720 48 port 10/100/1000mb Ethernet
8   48  CEF720 48 port 10/100/1000mb Ethernet
9   48  CEF720 48 port 10/100/1000mb Ethernet
4.3   7.2(1)       4.1(3)       Ok
6.4   7.2(1)       6.1(1)E2     Ok
2.6   ace2t_main_d A2(3.4)      Ok
1.0   12.2(18r)S1  12.2(33)SXI  Ok
5.6   8.5(2)       12.2(33)SXI  Ok
2.7   12.2(14r)S5  12.2(33)SXI  Ok
2  IDS 2 accelerator board     WS-SVC-IDSUPG
4  Distributed Forwarding Card WS-F6700-DFC3C
5  Policy Feature Card 3       WS-F6K-PFC3B
5  MSFC3 Daughterboard         WS-SUP720
6  Distributed Forwarding Card WS-F6700-DFC3C
7  Centralized Forwarding Card WS-F6700-CFC
8  Centralized Forwarding Card WS-F6700-CFC
9  Centralized Forwarding Card WS-F6700-CFC
I cannot get Inbound Qos to work on a Vlan Interface that is connected logically to a FWSM context.
The same simple config works in GNS3 (albeit on 3400's + ASA) and it also works on a 6509 with slightly different software versions on one of the Sup Modules.  see below:
Module
4  Distributed Forwarding Card WS-F6700-DFC3C     SALxxxxxxxx  1.0    Ok
4  Distributed Forwarding Card WS-F6700-DFC3C     SALxxxxxxxx  1.1    Ok <- Other working 6509
The config is pretty standard
Policy Map Limit
    Class class_subnet1
     police cir 104857500 bc 3276796 be 3276796
       conform-action transmit
       exceed-action drop
       violate-action drop
Class Map match-any class_subnet1 (id 1)
   Match access-group name acl_subnet1
Extended IP access list acl_subnet1
    10 permit ip 10.0.0.0 0.0.0.3 any
applied to interface vlan671
interface Vlan671
ip address 10.141.21.194 255.255.255.240
service-policy input Limit_subnet1
end
sh policy-map int vlan671
Vlan671
  Service-policy input: Limit_subnet1
    class-map: class_subnet1 (match-any)
      Match: access-group name acl_subnet1
      police :
        104856000 bps 3276796 limit 3276796 extended limit
      Earl in slot 4 :
        0 bytes
        5 minute offered rate 0 bps
        aggregate-forwarded 0 bytes action: transmit
        exceeded 0 bytes action: drop
        aggregate-forward 0 bps exceed 0 bps
      Earl in slot 5 :
        0 bytes
      Earl in slot 6 :
        0 bytes
Class-map: class-default (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
The Policy applied to the interface is just completely ignoring the configuration.
Any ideas?
I am sure it is related to the 6500 architecture in some way.
Same config is fine on the switch with the higher version on the sup card.
acampbell
Are you sure about your access list
That will allow packets from
10.0.0.1 & 10.0.0.2 to any address
Every thing else is ignored on your class map
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Thank you for your reply -
That access list is a subset/example of the 25 class maps and ACL's that are in the real policy map.  The class default should be seeing traffic anyway.  There is alot of traffic that is not covered by the acl's in the class maps that should hit the class-default and be passed.  As you can see there is zero bytes on both defined class maps and the default..  The 6500 is just ignoring the service-policy that has been applied.
but you are correct in that I have the mask wrong on some of my subnets as they are /29 and /28s  I need to change them to 0.0.0.7 and 0.0.0.15
Although this is not the problem, it is a step closer to the solution once the real problem is discovered
No one has faced this issue?
The different versions on the modules are for 10gig modules
