can not able to ping router ip using cisco layer 3 switch
dipak3254176
router ip 192.168.9.1 directally connceted to 192.168.9.254 (fa0/1 of layer 3 switch).
vlan ip 172.16.30.254/23
i can able to ping 192.168.9.1 if my source is 192.168.9.254 (fa0/1 of layer 3 switch)
i am not able to ping 192.168.9.1 from switch if source is 172.16.30.254
you can see runnig and ip route configuration
Switch#show ip route
Gateway of last resort is not set
C    192.168.9.0/24 is directly connected, FastEthernet0/1
     172.16.0.0/23 is subnetted, 1 subnets
C       172.16.30.0 is directly connected, Vlan30
Switch#show run
Building configuration...
Current configuration : 2262 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface FastEthernet0/1
no switchport
ip address 192.168.9.254 255.255.255.0
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
switchport access vlan 30
switchport mode access
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
ip address 172.16.4.31 255.255.248.0
interface Vlan30
ip address 172.16.30.254 255.255.254.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 5 15
end
Switch#
upour help is highly appreciated.
Giuseppe Larosa
Hello Dipak,
the router needs a static route for network 172.16.30.0/23 in order to answer to ICMP request sourced by 192.168.30.254
on the router
config t
ip route 172.16.30.0 255.255.254.0 192.168.9.254
exit
wr mem
This should fix your issue, to be noted it is not the switch the one that needs a configuration change.
Hope to help
Giuseppe
