Incoming and Outgoing calls not working on new E1
Hi, I have this router Cisco 2811, had to erase all the configuration, because I changed my E1 providor.
Now I cant make or receive calls. Please help!
here is my show run
Current configuration : 3249 bytes
version 12.4
hostname CUCMTCF
boot-start-marker
boot-end-marker
card type e1 0 0
no logging buffered
no logging console
enable secret 5 $1$0iXf$9YERhi2mGp2fwSODl4CzK1
no aaa new-model
clock timezone utc -6
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
no ip dhcp use vrf connected
ip dhcp pool Voice
no ip domain lookup
isdn switch-type primary-ni
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
codec preference 4 g729br8
voice class h323 1
h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /^0/ // type any national plan any isdn
voice-card 0
dspfarm
dsp services dspfarm
archive
log config
hidekeys
controller E1 0/0/0
pri-group timeslots 1-10,16
interface FastEthernet0/0
description DATOS
ip address 192.168.10.200 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.110.17.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.110.17.1
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
dial-peer voice 1 pots
destination-pattern 0.T
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 1000 voip
preference 2
voice-class codec 1
session target ipv4:10.110.17.1
dtmf-relay h245-alphanumeric
dial-peer voice 1005 voip
description llamadas Salientes Paises
destination-pattern 5T
voice-class codec 1
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 128
no auto-reg-ephone
max-ephones 40
max-dn 130
ip source-address 192.168.10.200 port 2000
timeouts interdigit 5
system message (TCF) BIT GUATEMALA
max-conferences 8 gain -6
transfer-system full-consult
Hi, now i'm just having outgoing calls that are failing.
Phone displays unknown number
*Jul 12 18:33:53.451: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a global identfier already present in the list of currently handled calls. It is being refused.
getting this on my debug
