CISCO 2811 not registering phones
Hi all!! I need your assistance, I'm having a cisco router 2811 and I cannot make it register any phone. I can ping from my computer but i cannot make that my CIPC registers, it remains on Registering.
Here's my run
CUCMTCF#show run
Building configuration...
Current configuration : 2815 bytes
version 12.4
hostname CUCMTCF
boot-start-marker
boot-end-marker
card type e1 0 0
no logging buffered
no logging console
enable secret 5 $1$0iXf$9YERhi2mGp2fwSODl4CzK1
no aaa new-model
clock timezone utc -6
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
no ip dhcp use vrf connected
ip dhcp pool Voice
no ip domain lookup
isdn switch-type primary-ni
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
codec preference 4 g729br8
voice class h323 1
h225 timeout tcp establish 3
voice-card 0
dspfarm
dsp services dspfarm
archive
log config
hidekeys
controller E1 0/0/0
pri-group timeslots 1-10,16
interface FastEthernet0/0
description DATOS
ip address 192.168.10.200 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.110.17.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.110.17.1
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
dial-peer voice 1 pots
destination-pattern 0.T
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 1000 voip
preference 2
voice-class codec 1
session target ipv4:192.168.10.200
dtmf-relay h245-alphanumeric
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 128
max-ephones 40
max-dn 130
timeouts interdigit 5
system message (TCF) BIT GUATEMALA
max-conferences 8 gain -6
transfer-system full-consult
9 Replies 9
johnd2310
Level 8
Level 8
You are missing some commands under telephony-service. You need the ip source-address X.X.X.X port 2000.
Have a look at the following doc:
http://www.cisco.com/c/en/us/support/docs/voice/h323/25100-config-troubleshoot-its.html
John
**Please rate posts you find helpful**
done, now I'm getting registered my 7911 phones, but not my ip phones. My idea is this
simple network
Thanks!
hi,
Have you configure a phone for you ip communicator?
e.g.
ephone 1
mac-address HHHH.HHHH.HHHH
type cipc
button 1:1
John
yes, but this CIPC it's on a different subnet that it's the 7911.
thanks
can you ping CIPC from the router? Have you checked that Windows firewall is not blocking CIPC traffic?
John
I can't ping CIPC from the router
thanks
check firewall on the PC and allow CIPC to talk to router.
John
what if I have 1 router and 2 different switches.
One switch for voice and another for data, but I want it also for CIPC
Hi Johnd2310,
I cannot make outgoing calls, and i'm getting this message in my debug
*Jul 12 18:33:53.451: %CALL_CONTROL-6-CALL_LOOP: The incoming call has a global identfier already present in the list of currently handled calls. It is being refused.
Help!
