Incorrect BW, txload, rxload stats on GB interface on 3020 Blade Switch
seanpfoley
It was noted that in the Device Manager, ports were being displayed with 100% utilization which is not expected with our applications. Digging through the config and "show interface" it looks like this could be related to the fact that BW is showing only 10000 Kbit on all the gigabit interfaces. It appears that txload and rxload must be derived from this incorrect number. Is there an actual speed problem or is this just with the stats? Is there a way to fix it?
Version 12.2(25)SEF1
WS-CBS3020-HPQ
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001b.0db6.4e81 (bia 001b.0db6.4e81)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 255/255, txload 43/255, rxload 35/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1385000 bits/sec, 805 packets/sec
5 minute output rate 1693000 bits/sec, 753 packets/sec
3759796144 packets input, 2382887840 bytes, 0 no buffer
Received 112034 broadcasts (0 multicast)
0 watchdog, 55 multicast, 0 pause input
1278989763 packets output, 2694728552 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Sean
pciaccio
Level 4
Level 4
The link bandwidth util is calculated with the bandwidth value on the interface. under the interface use the bandwidth command. Set it to the value you want your stts to be based upon. You may also want to use the load-theshold command and set it for 30 secs. This recalculates the bandwidth util every 30 secs as opposed to its default of 300 secs...Good Luck...
