Connecting a VLAN'ed network to a dual homed host
jim.billings
We have successively implemented a routed VLAN setup at our site with one problem. We need to be able to connect to a couple of hosts on a seperate network that is not in our control. These hosts are dual homed with the second NIC on our VLAN 2 Server network. The problem is when we try to connect to these hosts from the other VLAN's. I believe the traffic is getting to the hosts from the other vlans, but is being dropped or routed to the seperate network gateway. How would you recommend connecting to these hosts?
We have these VLAN's setup:
VLAN 1 shutdown
172.17.2.0/24 = VLAN 2 Servers
172.17.3.0/24 = VLAN 3 Workstations
172.17.10.0/24 = VLAN 10 Management
the other network is 192.168.0.0 /16 that is out of our control.
Dual host #1
NIC1 192.168.2.? GW 192.168.2.1
NIC2 172.17.2.5 GW 172.17.2.254
Dual host #2
NIC2 172.17.2.6 GW 172.17.2.254
Jon Marshall
Jim
Either
1) Add routes to the hosts for your vlan subnets but this might not be possible as they are out of your control
OR
2) Use NAT ie.
access-list 101 permit ip 172.17.3.0 0.0.0.255 host 172.17.2.5
access-list 101 permit ip 172.17.3.0 0.0.0.255 host 172.17.2.6
on vlan interfaces
int vlan 3
ip nat inside
int vlan 10
ip nat inside
int vlan 2
ip nat outside
ip nat inside source list 101 interface vlan 2 overload
then any traffic going to the hosts will seem to be coming from the vlan 2 IP address and so the hosts should use their vlan 2 gateway rather than the 192.168.2.1 gateway.
Jon
6 Replies 6
Jon Marshall
Jim
Either
OR
2) Use NAT ie.
on vlan interfaces
int vlan 3
ip nat inside
int vlan 10
ip nat inside
int vlan 2
ip nat outside
Jon
I will give it a try. Can I add these to the existing ACL's?
Here is what I have on the Main switch:
snip
interface Vlan1
no ip address
shutdown
interface Vlan2
description SERVERS
ip address 172.17.2.254 255.255.255.0
interface Vlan3
description WG3
ip address 172.17.3.254 255.255.255.0
ip access-group 110 in
ip helper-address 172.17.2.1
snip
interface Vlan10
description MANAGEMENT
ip address 172.17.10.254 255.255.255.0
snip
interface Vlan100
description INTERNET
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 172.17.100.1
ip http server
access-list 110 permit udp any eq bootpc any
access-list 110 permit ip 172.17.3.0 0.0.0.255 172.17.2.0 0.0.0.255
access-list 110 permit ip 172.17.3.0 0.0.0.255 172.17.10.0 0.0.0.255
access-list 110 permit ip 172.17.3.0 0.0.0.255 172.17.100.0 0.0.0.255
access-list 110 deny ip 172.17.3.0 0.0.0.255 172.17.4.0 0.0.0.255
access-list 110 deny ip 172.17.3.0 0.0.0.255 172.17.5.0 0.0.0.255
access-list 110 deny ip 172.17.3.0 0.0.0.255 172.17.6.0 0.0.0.255
access-list 110 deny ip 172.17.3.0 0.0.0.255 172.17.7.0 0.0.0.255
access-list 110 deny ip 172.17.3.0 0.0.0.255 172.17.8.0 0.0.0.255
access-list 110 deny ip 172.17.3.0 0.0.0.255 172.17.12.0 0.0.0.255
access-list 110 permit ip 172.17.3.0 0.0.0.255 any
access-list 111 permit udp any eq bootpc any
access-list 111 permit ip 172.17.4.0 0.0.0.255 172.17.2.0 0.0.0.255
access-list 111 permit ip 172.17.4.0 0.0.0.255 172.17.10.0 0.0.0.255
access-list 111 permit ip 172.17.4.0 0.0.0.255 172.17.100.0 0.0.0.255
access-list 111 deny ip 172.17.4.0 0.0.0.255 172.17.3.0 0.0.0.255
access-list 111 deny ip 172.17.4.0 0.0.0.255 172.17.5.0 0.0.0.255
access-list 111 deny ip 172.17.4.0 0.0.0.255 172.17.6.0 0.0.0.255
access-list 111 deny ip 172.17.4.0 0.0.0.255 172.17.7.0 0.0.0.255
access-list 111 deny ip 172.17.4.0 0.0.0.255 172.17.8.0 0.0.0.255
access-list 111 deny ip 172.17.4.0 0.0.0.255 172.17.12.0 0.0.0.255
access-list 111 permit ip 172.17.4.0 0.0.0.255 any
snip
int vlan 3
ip nat inside
this command is not available on our 3560G switch
Jim
Apologies. For some reason i assumed we were talking about a 6500 switch, my fault.
Unfortunately the only switch that supports NAT is the 6500 so you will have to go with option 1.
Jon
We are working to get them to add the routes to the server on the other network. Thanks, again.
Jim
I have in LAN router cisco and router no cisco,
the problem that i need to shared connect to internet (Backup)
thanks
