Incorrect entry in 4506 configuration
cwharton1
Current configuration:
line con 0
 stopbits 1
line 1 5
 password ciscocisco
 login
 exec-character-bits 8
 length 0
 width 0
 no history
 international
 transport input telnet
 speed 9600
I need to delete line 1 5, but I get an error message (Vty line 1 doesn't exist).  Apparently, because of this bogus entry, I cannot create line vty 0 4.  Is there any way to delete this entry without making a copy and re-configuring the whole switch?
michael o'nan
Level 4
Level 4
That doesn't appear to be a VTY line...? I have only seen it as line vty 1
Yes - that is the problem.  This is the way the switch was configured when I got here.  I know I could set the switch to original configuration and re-program it, I was just trying to avoid that.  But there doesn't seem to be any way to delete the bad lines.
Have you received an answer at all? I am running into the same issue
