Increase Bandwidth
thanhtq66
Community Member
I want to connect 2 NIC from server to Switch to increase banwidth, the questions is:
1- Can I configure 1 IP address for NIC.
2- What functions of the switch support.
3- How do I configure step by step.
I use Cat 3560
JORGE RODRIGUEZ
Level 11
Level 11
Yes you can, go over this link, etherchannel overview and config examples.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.1_19_ea1/configuration/guide/swethchl.html#wp1042006
Pls rate any helpful post.
Jorge
Jorge Rodriguez
thanks for rapid reply!
bvsnarayana03
Level 10
Level 10
Connecting 2 NIC's on server to switch??
I suppose u r asking about the OS support for this. You can use "Teaming" a term used for combining 2 NIC's as logically 1, & then assign single IP to the team.
Detailed procedure may be available on server networking documentation site or CD.
Thank You for more information!
