ingress queues,frame placement, in layer 2 switch
sarahr202
Level 5
Level 5
hi every body!
1)i just want to know when a layer 2 switch receives a frame on port, how does it determine in which ingress queue the frame be placed?
is it decided by qos in frame?
thanks a lot!
Prashanth Krishnappa
Not all platforms support input scheduling but if your switch does, your understanding is correct. It depends on
1)QoS markings on the incoming packet
2)The queue selected depends on cos/dscp to ingress Q map
Here is some documentation(I picked 3750 for example)
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swqos.html#wp1065146
