Initial boot "System received a System Error"
pelston3233
Hello all,
I need help trying to manually intervene and stop a newly purchased used Cisco 2811 router that loops and keeps trying to upgrade the ROMMON and self decompress the image? Here's the message:
Writing crashinfo to flash:crashinfo_20170418-014517-UTC
m
*** System received a System Error ***
signal= 0x16, code= 0x0, context= 0x49691318
PC = 0x4007de54, Cause = 0x2020, Status Reg = 0x34008002
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Initializing memory for ECC
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
Leo Laohoo
If the router has NM/NME &/or WIC/HWIC cards, pull them all out.
Console into the router and reboot the router, we want to see everything (and don't edit things out, IP addresses excluded).
