Initial Switch Configuration
David Dembrow
Community Member
I am looking for a minimal baseline switch configuration to use setting up a set of switches.
The process now is to reset the switch to factory defaults, assign an ip address with switch/telnet password.  Then telnet to the switch and manually enter commands to set up ssh/scp.  Secure copy a baseline switch configuration file to startup-config.  Finally, secure shell login to the switch and copy startup-config running-config.  This is repeated for a chain of about a dozen switches.
Is there a simpler solution?  What is a minimal set of startup-config entries?
Thanks for any suggestions.
A simpler solution could be the use of "Smart Install":
http://www.cisco.com/en/US/docs/switches/lan/smart_install/release_12.2_52_se/configuration/guide/tasks.html
But I'm not sure if setting up the environment is useful for just a dozen switches.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
