Inlet and outlet temperature N/o in 6500
AK002
Please sort me out the issue for the below module showing inlet and outlet temperature N/o.
How to find the issue related to sensor in the module or something else to troubleshoot in the module to find the issue.
ws-x6548-rj45
module 8:
module 8 power-output-fail: OK
module 8 outlet temperature: N/O
module 8 inlet temperature: N/O
module 8 device-1 temperature: N/O
module 8 device-2 temperature: N/O
witch#sh diagnostic result module 8
Current bootup diagnostic level: complete
Module 8: SFM-capable 48-port 10/100 Mbps RJ45
Overall Diagnostic Result for Module 8 : PASS
Diagnostic level at card bootup: complete
Test results: (. = Pass, F = Fail, U = Untested)
1) TestLoopback:
Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
2) TestL3VlanMet -------------------> .
3) TestIngressSpan -----------------> .
4) TestEgressSpan ------------------> .
5) TestAsicMemory ------------------> U
6) TestEobcStressPing --------------> U
7) TestFirmwareDiagStatus ----------> .
8) TestAsicSync --------------------> .
9) TestUnusedPortLoopback:
U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U
U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  .
10) TestErrorCounterMonitor ---------> .
11) TestPortTxMonitoring:
12) TestLtlFpoeMemoryConsistency ----> .
13) TestRwEngineOverSubscription ----> U
thanks in advance...
regards //Arun
5 Replies 5
InayathUlla Sharieff
Hi Arun,
As there are no outputs attached (i.e show tech or show logs) I dont know if there is any logs been displayed over there.
, it seems to meit's a minor issue which can be fixed by reseating the module 8. Below is my action plan.
1.Please physically reseat the module 8.
2.I see you have similar module ws-x6548-rj45 in slot 8 and 9 on the switch.
I will suggest you to swap the module in slot 8 and slot 9.
The issue can be with the module, chasis or the power supply. In order to
isolate it you can try the above mentioned action plan.
Inayath
*Plz rate the usefull posts.
Thanks inayathulla,
I already done the reset for module
But still the problem persists..
Is any otherway way to troubleshoot this? Pls advice.
Arun
We may want to look at the airflow around the chassis. There may be something
blocking the intake, or there may be a temperature problem in the room the
system is in.  Additionally we want to ensure there is not another device
blowing hot air into the intake.
If all this are okay then only thing I could see is to have the module replaced.
Inayath
ok thanks..
But
N/0 in the sense not operational.
Hi Arun,
Yes thats correct. N/O means not operational.
As suggested please check all the following things:
1- Air intake
2- Reseat of the module
3-swapping the module to anther slot.
Inayath
