IKE Phase 2 SA expires immediately - site 2 site ipsec over gre
Philippe Latu
I am migration an IPsec site to site VPN config to a new ASR1001 router «facing» a Linux box (ipsec-tools + racoon).
As the Debian Linux does not offer VTI, I am using a crypto map.
The working config is given below with the corresponding logs on the Linux side.
When I try to apply this previously working config to the ASR1001, I get the following error :
000855: *Dec 12 18:28:21.859 UTC: %ACE-3-TRANSERR: IOSXE-ESP(14): IKEA trans 0x1350; opcode 0x60; param 0x2EE; error 0x5; retry cnt 0
Any hint on the error code 0x5 ?
The Linux side logs show timing problems ...
Dec 12 18:50:19 FAKE-AUCH-GW racoon: INFO: initiate new phase 1 negotiation: 194.214.196.2[500]<=>130.120.124.8[500]
Dec 12 18:50:19 FAKE-AUCH-GW racoon: INFO: begin Identity Protection mode.
Dec 12 18:50:19 FAKE-AUCH-GW racoon: INFO: received Vendor ID: CISCO-UNITY
Dec 12 18:50:19 FAKE-AUCH-GW racoon: INFO: received Vendor ID: DPD
Dec 12 18:50:19 FAKE-AUCH-GW racoon: INFO: received Vendor ID: draft-ietf-ipsra-isakmp-xauth-06.txt
Dec 12 18:50:19 FAKE-AUCH-GW racoon: INFO: ISAKMP-SA established 194.214.196.2[500]-130.120.124.8[500] spi:5f8e6339fb954d45:e513d25e42e19d11
Dec 12 18:50:20 FAKE-AUCH-GW racoon: INFO: initiate new phase 2 negotiation: 194.214.196.2[500]<=>130.120.124.8[500]
Dec 12 18:50:39 FAKE-AUCH-GW racoon: INFO: respond new phase 2 negotiation: 194.214.196.2[500]<=>130.120.124.8[500]
Dec 12 18:50:50 FAKE-AUCH-GW racoon: NOTIFY: the packet is retransmitted by 130.120.124.8[500] (1).
Dec 12 18:50:50 FAKE-AUCH-GW racoon: INFO: IPsec-SA expired: ESP/Transport 130.120.124.8[500]->194.214.196.2[500] spi=30866420(0x1d6fbf4)
Dec 12 18:50:50 FAKE-AUCH-GW racoon: WARNING: PF_KEY EXPIRE message received from kernel for SA being negotiated. Stopping negotiation.
Dec 12 18:50:50 FAKE-AUCH-GW racoon: INFO: IPsec-SA expired: AH/Transport 130.120.124.8[500]->194.214.196.2[500] spi=258959(0x3f38f)
Dec 12 18:50:59 FAKE-AUCH-GW racoon: INFO: initiate new phase 2 negotiation: 194.214.196.2[500]<=>130.120.124.8[500]
Dec 12 18:51:00 FAKE-AUCH-GW racoon: NOTIFY: the packet is retransmitted by 130.120.124.8[500] (1).
Dec 12 18:51:09 FAKE-AUCH-GW racoon: INFO: IPsec-SA expired: ESP/Transport 130.120.124.8[500]->194.214.196.2[500] spi=95427747(0x5b01ca3)
Dec 12 18:51:09 FAKE-AUCH-GW racoon: WARNING: PF_KEY EXPIRE message received from kernel for SA being negotiated. Stopping negotiation.
Dec 12 18:51:09 FAKE-AUCH-GW racoon: INFO: IPsec-SA expired: AH/Transport 130.120.124.8[500]->194.214.196.2[500] spi=159198575(0x97d2d6f)
Dec 12 18:51:09 FAKE-AUCH-GW racoon: INFO: respond new phase 2 negotiation: 194.214.196.2[500]<=>130.120.124.8[500]
Dec 12 18:51:10 FAKE-AUCH-GW racoon: NOTIFY: the packet is retransmitted by 130.120.124.8[500] (1).
! IOS Running config
crypto isakmp policy 10
encr aes 256
hash md5
authentication pre-share
group 2
crypto isakmp key MY-0WN-T3RR1F1C-PR35H4R3D-K3Y address 192.0.2.66 no-xauth
crypto ipsec transform-set MY-0WN-TS-MD5 ah-md5-hmac esp-aes 256 esp-md5-hmac
mode transport
crypto map MY-0WN-MAP 1 ipsec-isakmp
set peer 192.0.2.66
set transform-set MY-0WN-TS-MD5
set pfs group2
match address 120
interface Tunnel0
bandwidth 45000
ip address 198.51.100.1 255.255.255.252
no ip redirects
no ip proxy-arp
ip mtu 1400
ip virtual-reassembly in
ip tcp adjust-mss 1360
tunnel source GigabitEthernet0/0
tunnel destination 192.0.2.66
tunnel path-mtu-discovery
tunnel bandwidth transmit 45000
tunnel bandwidth receive 45000
interface GigabitEthernet0/0
ip address 192.0.2.34 255.255.255.224
no ip redirects
no ip proxy-arp
duplex full
speed 1000
media-type gbic
negotiation auto
Linux side logs
Dec 12 08:18:30 GLA racoon: INFO: ISAKMP-SA expired 192.0.2.66[500]-192.0.2.34[500] spi:88ed3c49ea8ffe38:e568a2dd27cbec5d
Dec 12 08:18:30 GLA racoon: INFO: ISAKMP-SA deleted 192.0.2.66[500]-192.0.2.34[500] spi:88ed3c49ea8ffe38:e568a2dd27cbec5d
Dec 12 08:18:31 GLA racoon: INFO: respond new phase 1 negotiation: 192.0.2.66[500]<=>192.0.2.34[500]
Dec 12 08:18:31 GLA racoon: INFO: begin Identity Protection mode.
Dec 12 08:18:31 GLA racoon: INFO: received Vendor ID: RFC 3947
Dec 12 08:18:31 GLA racoon: INFO: received Vendor ID: draft-ietf-ipsec-nat-t-ike-07
Dec 12 08:18:31 GLA racoon: INFO: received Vendor ID: draft-ietf-ipsec-nat-t-ike-03
Dec 12 08:18:31 GLA racoon: INFO: received Vendor ID: draft-ietf-ipsec-nat-t-ike-02#012
Dec 12 08:18:31 GLA racoon: INFO: received Vendor ID: DPD
Dec 12 08:18:31 GLA racoon: INFO: received Vendor ID: draft-ietf-ipsra-isakmp-xauth-06.txt
Dec 12 08:18:31 GLA racoon: [192.0.2.34] INFO: received INITIAL-CONTACT
Dec 12 08:18:31 GLA racoon: INFO: ISAKMP-SA established 192.0.2.66[500]-192.0.2.34[500] spi:88ed3c49e027808c:b17ba35c5b7f1e82
Dec 12 08:18:31 GLA racoon: INFO: respond new phase 2 negotiation: 192.0.2.66[500]<=>192.0.2.34[500]
Dec 12 08:18:31 GLA racoon: INFO: Update the generated policy : 192.0.2.34/32[0] 192.0.2.66/32[0] proto=any dir=in
Dec 12 08:18:31 GLA racoon: INFO: IPsec-SA established: AH/Transport 192.0.2.66[500]->192.0.2.34[500] spi=88493238(0x5464cb6)
Dec 12 08:18:31 GLA racoon: INFO: IPsec-SA established: ESP/Transport 192.0.2.66[500]->192.0.2.34[500] spi=21367141(0x1460965)
Dec 12 08:18:31 GLA racoon: INFO: IPsec-SA established: AH/Transport 192.0.2.66[500]->192.0.2.34[500] spi=1579505880(0x5e2558d8)
Dec 12 08:18:31 GLA racoon: INFO: IPsec-SA established: ESP/Transport 192.0.2.66[500]->192.0.2.34[500] spi=838280164(0x31f723e4)
Could you adjust your transform set?
Right now you have: crypto ipsec transform-set MY-0WN-TS-MD5 ah-md5-hmac esp-aes 256 esp-md5-hmac
Could you change this to strictly ESP or AH on both sides instead of mixing them.
There is a known issue with the ASR and mixing AH/ESP in the ipsec config. I will post it below:
CSCtb60545 / CSCsv96390
Mixing AH and ESP in transform set on ASR might not work. This is an enhancement request to introduce support for this.
Symptoms:
Router may display following messages continuously on the console:
%ACE-3-TRANSERR: ASR1000-ESP(14): IKEA trans 0x27E; opcode 0x60; param 0x2A;
Conditions:
This symptom is observed on a Cisco ASR1000 series router when functions as a IPSec
end-point, and when nested SA transformation is applied, such as:
crypto ipsec transform-set transform-1 ah-sha-hmac esp-3des esp-md5-hmac
crypto ipsec transform-set transform-1 ah-md5-hmac esp-3des esp-md5-hmac
Workaround:
Remove unsupported configuration.
8 Replies 8
Gabriel Hill
Would it be possible for you to paste the output of a "debug crypto ipsec" on the ASR after restarting the racoon service on the Debian box (/etc/init.d/racoon restart)?
Here it is ... in the attached text file.
Just for verification could you post your ipsec-tools.conf - it should be in the /etc folder.
Also can you post the following from the ASR:
show version
show crypto ace spi (you may have to type this command out as it may be hidden, also be sure to do this when interestingt traffic is going between the ASR and linux box.)
Here are the requested informations.
As a proof of interesting trafic, I can only show the access list matches
asr1001-gw#sh ip access-lists 120
Extended IP access list 120
    10 permit ip host 130.120.124.8 host 194.214.196.2 (3960 matches)
asr1001-gw#sh crypto ace spi
SPI in use ........................... 0
Normal SPI allocated ................. 67
HA SPI in allocated .................. 0
Free via flow id ..................... 0
Free via SPI ......................... 0
Errors
Duplicate free ....................... 0
Set in-use SPI to SPI table .......... 0
Clear in-use SPI from SPI table ...... 0
Free in-use SPI................ ...... 0
asr1001-gw#sh crypto session
Crypto session current status
Interface: GigabitEthernet0/0/0.2
Session status: UP-IDLE
Peer: 194.214.196.2 port 500
  IKEv1 SA: local 130.120.124.8/500 remote 194.214.196.2/500 Active
  IPSEC FLOW: permit ip host 130.120.124.8 host 194.214.196.2
        Active SAs: 0, origin: crypto map
On the Linux side :
# setkey -DP
(per-socket policy)
        out(socket) none
        created: Dec 12 23:27:15 2012  lastused: Dec 13 09:06:14 2012
        lifetime: 0(s) validtime: 0(s)
        spid=340 seq=1 pid=5037
        refcnt=1
(per-socket policy)
        in(socket) none
        spid=331 seq=2 pid=5037
        refcnt=1
194.214.196.2[any] 130.120.124.8[any] 255
        out prio def ipsec
        ah/transport//require
        esp/transport//require
        created: Dec 12 08:34:14 2012  lastused:
        spid=161 seq=3 pid=5037
        refcnt=5
130.120.124.8[any] 194.214.196.2[any] 255
        fwd prio def ipsec
        spid=154 seq=4 pid=5037
        refcnt=1
        in prio def ipsec
        created: Dec 12 08:34:14 2012  lastused: Dec 12 23:27:15 2012
        spid=144 seq=0 pid=5037
        refcnt=1
# setkey -Dp
130.120.124.8[0] 194.214.196.2[0]
        ah mode=transport spi=6347238(0x0060d9e6) reqid=0(0x00000000)
        seq=0x00000000 replay=0 flags=0x00000000 state=larval
        created: Dec 13 09:07:22 2012   current: Dec 13 09:07:27 2012
        diff: 5(s)      hard: 30(s)     soft: 0(s)
        last:                           hard: 0(s)      soft: 0(s)
        current: 0(bytes)       hard: 0(bytes)  soft: 0(bytes)
        allocated: 0    hard: 0 soft: 0
        sadb_seq=1 pid=5038 refcnt=0
        esp mode=transport spi=73839316(0x0466b2d4) reqid=0(0x00000000)
        sadb_seq=2 pid=5038 refcnt=0
194.214.196.2[0] 130.120.124.8[0]
        ah mode=transport spi=0(0x00000000) reqid=0(0x00000000)
        sadb_seq=3 pid=5038 refcnt=0
        ah mode=transport spi=33128108(0x01f97eac) reqid=0(0x00000000)
        created: Dec 13 09:07:09 2012   current: Dec 13 09:07:27 2012
        diff: 18(s)     hard: 30(s)     soft: 0(s)
        sadb_seq=4 pid=5038 refcnt=0
        esp mode=transport spi=226399628(0x0d7e958c) reqid=0(0x00000000)
        sadb_seq=0 pid=5038 refcnt=0
Symptoms:
Conditions:
Workaround:
That's it !      A big thank you for your time
Following your advice, I set up a new ESP only transform set and both IKE phases worked perfectly.
It seems the issue you mentionned is independant of any hash or encryption algorithm and ASR1k IOS XE 3.8 doesn't support AH+ESP (yet ...).
crypto ipsec transform-set AUCH-TS-ESP esp-aes 256 esp-md5-hmac
mode transport
crypto map AUCH-CRYPTO-MAP 1 ipsec-isakmp
set peer 194.214.196.2
set transform-set AUCH-TS-ESP
set pfs group5
match address 120
On the Linux side, the racoon process restart gives the following logs  which end by IPsec-SA established (phase 2 up) :
Dec 13 23:00:25 FAKE-AUCH-GW racoon: INFO: @(#)ipsec-tools 0.8.0 (http://ipsec-tools.sourceforge.net)
Dec 13 23:00:25 FAKE-AUCH-GW racoon: INFO: @(#)This product linked OpenSSL 1.0.1c 10 May 2012 (http://www.openssl.org/)
Dec 13 23:00:25 FAKE-AUCH-GW racoon: INFO: Reading configuration from "/etc/racoon/racoon.conf"
Dec 13 23:00:25 FAKE-AUCH-GW racoon: INFO: 194.214.196.2[500] used for NAT-T
Dec 13 23:00:25 FAKE-AUCH-GW racoon: INFO: 194.214.196.2[500] used as isakmp port (fd=8)
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: respond new phase 1 negotiation: 194.214.196.2[500]<=>130.120.124.8[500]
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: begin Identity Protection mode.
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: received Vendor ID: RFC 3947
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: received Vendor ID: draft-ietf-ipsec-nat-t-ike-07
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: received Vendor ID: draft-ietf-ipsec-nat-t-ike-03
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: received Vendor ID: draft-ietf-ipsec-nat-t-ike-02#012
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: received Vendor ID: DPD
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: received Vendor ID: draft-ietf-ipsra-isakmp-xauth-06.txt
Dec 13 23:00:34 FAKE-AUCH-GW racoon: [130.120.124.8] INFO: received INITIAL-CONTACT
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: ISAKMP-SA established 194.214.196.2[500]-130.120.124.8[500] spi:bb2143ada18ff382:4ec392f1578eac7c
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: respond new phase 2 negotiation: 194.214.196.2[500]<=>130.120.124.8[500]
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: Update the generated policy : 130.120.124.8/32[0] 194.214.196.2/32[0] proto=any dir=in
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: IPsec-SA established: ESP/Transport 194.214.196.2[500]->130.120.124.8[500] spi=94595988(0x5a36b94)
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: IPsec-SA established: ESP/Transport 194.214.196.2[500]->130.120.124.8[500] spi=3846049996(0xe53e10cc)
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: IPsec-SA established: ESP/Transport 194.214.196.2[500]->130.120.124.8[500] spi=53239394(0x32c5e62)
Dec 13 23:00:34 FAKE-AUCH-GW racoon: INFO: IPsec-SA established: ESP/Transport 194.214.196.2[500]->130.120.124.8[500] spi=3071153643(0xb70e15eb
I can connect my debian with my cisco. I download you ipsec-tools.conf for compare with my but can you put you
/etc/racoon/racoon.conf ?
thank you very much.
If you can read french or read through automated translation (which can be quite funny), I started a documentation at the following page : http://www.inetdoc.net/articles/site2site-ipsecvpn/
Here is a sample racoon.conf :
# Please read racoon.conf(5) for details, and read also setkey(8).
log info;
path pre_shared_key "/etc/racoon/psk.txt";
padding {
  strict_check on;
listen {
  isakmp 192.0.2.66;
remote 192.0.2.34 {
  my_identifier address 192.0.2.66;
  exchange_mode main;
  proposal_check obey;
  proposal {
    lifetime time 86400 secs;
    encryption_algorithm aes 256;
    hash_algorithm md5;
    authentication_method pre_shared_key;
    dh_group 14;
  generate_policy on;
  initial_contact on;
sainfo anonymous {
  lifetime time 3600 secs;
  pfs_group 14;
  authentication_algorithm hmac_md5;
  compression_algorithm deflate;
