input drops on trunk due to keepalives
chandu.84
we have a setup 6500-------> 2970
Not much traffic on a trunk but we have quite a lot of input drops on 2970
but the input drops dissapears if i disable keepalives
can someone help me out with this ?
6506 interface :
interface FastEthernet3/15
switchport
switchport trunk allowed vlan 45
switchport mode trunk
switchport nonegotiate
no ip address
no logging event link-status
load-interval 30
speed 100
duplex full
no snmp trap link-status
FastEthernet3/15 is up, line protocol is up (connected)
  Hardware is C6k 100Mb 802.3, address is 0012.dafe.85be (bia 0012.dafe.85be)
  Description: SRC=VL-MO-RI009-Fas3-15, DST=VL-DV-SG001-Gig0-24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:32, output 00:00:01, output hang never
  Last clearing of "show interface" counters 2w3d
  Input queue: 0/2000/165204/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     809897 packets input, 478719601 bytes, 0 no buffer
     Received 50975 broadcasts (37132 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     3045538 packets output, 247983738 bytes, 0 underruns
2970 configuration:
interface GigabitEthernet0/24
no ip address
duplex full
speed 100
no mdix auto
GigabitEthernet0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0011.92c6.e498 (bia 0011.92c6.e498)
  Description: SRC=VL-DV-SG001-Gig0-24, DST=VL-MO-RI009-Fas3-15
  input flow-control is off, output flow-control is off
  Last input 00:00:01, output 00:00:05, output hang never
     2806097 packets input, 228508296 bytes, 0 no buffer
     Received 2430932 broadcasts (0 multicast)
     0 watchdog, 2212762 multicast, 0 pause input
     762370 packets output, 463878259 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
smogra
Please clear the counters once and run the command 'sh int fa3/15" few times to see if the input queue drops increment. From the output
there seems to be no packet clogged in the queue currently.
The system counts input queue drops if the number of packet buffers       allocated to the interface is exhausted or reaches its maximum  threshold. You       can increase the maximum queue value with the hold-queue command for each interface       (the queue length value can be between 0 and 4096. The default value  is       75).
Refer to this link as well. This will highlight more on the input queue drops.
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml
Cheers
Sweta
Please rate the useful posts.
Thanx for getting back to me Sweta
The thing is there is no traffic passing through the interface so there should not be any input Queue and there should not be any input drops and the input drops dissappear when i disable keepalives.
By default keepalives are for 10sec and for ethernet interfaces, keepalives are sent to the same interface to check if the interface is alive and for every 1 min i see 6 input drops which represents that all the keepalives are dropping.
and i see drops only on 6500 end not on 2970.
