Input error and CRC error on WAN interface.
nihammimm
I have noticed input error and CRC error on our mpls wan interface , but we dont have packet drops or communication issue now.
Is it normal for WAN interfaces ?
2 Accepted Solutions
Dennis Mink
What sort of interface is it?
if its ethernet and you connect to your provider on it, make sure you verify the duplex settingss. some providers set their interface to "auto" rather then hard set . This can cause CRC errors and no drops, but serious performance degradation.
Just a thought
Please remember to rate useful posts, by clicking on the stars below.
Joseph W. Doherty
isclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any  purpose.  Information provided is for informational purposes only and  should not be construed as rendering professional advice of any kind.  Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever  (including, without limitation, damages for loss of use, data or  profit) arising out of the use or inability to use the posting's  information even if Author has been advised of the possibility of such  damage.
Posting
Agree with Alain, but want to emphasis it should be a very small percentage.
Cisco says (for serial lines):
Note
Any  input error value for cyclic redundancy check (CRC) errors, framing  errors, or aborts above 1 percent of the total interface traffic  suggests some kind of link problem that should be isolated and repaired.
Personally I prefer no worst than 1 in 1,000 or even better 1 in 10,000.
cadet alain
Yes it could be as long as they are a small percentage of total input packets.
Regards.
Alain.
Dennis Mink
Just a thought
Joseph W. Doherty
isclaimer
Posting
Note
nihammimm
Thanx all for information
This is serial interface only.
