Input error on uplink interface
can someone please help what is cause of input error on interface on switch ASR1001
cdc-tel-choke-1#sh int Gi0/0/3
GigabitEthernet0/0/3 is up, line protocol is up
  Hardware is ASR1001, address is 5057.a883.eb03 (bia 5057.a883.eb03)
  Description: AIS WAN Router
  Internet address is 10.203.20.18/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 55/255, rxload 87/255
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is T
  output flow-control is on, input flow-control is on
  Last input 00:00:20, output 00:02:28, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 771400
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  5 minute input rate 343367000 bits/sec, 62691 packets/sec
  5 minute output rate 218495000 bits/sec, 60698 packets/sec
     248856430712 packets input, 164909422353975 bytes, 0 no buffer
     Received 6072 broadcasts (0 IP multicasts)
     1484734 input errors, 0 CRC, 0 frame, 1484734 overrun, 0 ignored
     0 watchdog, 262367 multicast, 0 pause input
     287740930198 packets output, 198463984257321 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     262367 unknown protocol drops
     0 lost carrier, 0 no carrier, 490 pause output
#sh run int Gi0/0/3
Building configuration...
Current configuration : 288 bytes
interface GigabitEthernet0/0/3
description AIS WAN Router
ip address 10.203.20.18 255.255.255.252
ip nat outside
ip flow monitor Monitor-FNF-IWAN input
ip flow monitor Monitor-FNF-IWAN output
ip access-group block-wan-out out
negotiation auto
service-policy output QOS2WAN
end
Leo Laohoo
@AscensionNetworkteam wrote:
1484734 overrun
MTU mismatch?
