Input Errors and Overrun Errors on Router LAN Interface
abithbasha
Dear All,
I am seeing lot of Input Errors, this is between LAN uplink of Router port GE 0/1 to Cisco Switch 2960 Gig 1/0/6, is this input errors and overrun is normal between the LAN uplink? Below configuration for reference, I am seeing lot disconnection between our office to our DataCenter, is this because of this input errors, overrun and unknown protocol drops
Router:-CISCO2911/K9
interface GigabitEthernet0/1
description Transit-VLAN
ip address 10.84.103.1 255.255.255.0
ip flow monitor NTAmon input
ip flow monitor NTAmon output
ip nat inside
ip virtual-reassembly in
zone-member security LAN
ip tcp adjust-mss 1300
ip policy route-map PBR
duplex auto
speed auto
MEA-IN-MUM-RT01#sh int gig 0/1
GigabitEthernet0/1 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is 442b.037f.f689 (bia 442b.037f.f689)
Description: Transit-VLAN
Internet address is 10.84.103.1/24
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 09:24:40
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 114000 bits/sec, 75 packets/sec
5 minute output rate 154000 bits/sec, 65 packets/sec
9246658 packets input, 2364825917 bytes, 0 no buffer
Received 145082 broadcasts (7314 IP multicasts)
3054 input errors, 0 CRC, 0 frame, 3048 overrun, 0 ignored
0 watchdog, 9006 multicast, 0 pause input
7982324 packets output, 3342113006 bytes, 0 underruns
1128 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Switch : - WS-C2960S-48TS-L
interface GigabitEthernet1/0/6
description TRANSIT-LAN
switchport trunk allowed vlan 1,10,104
switchport mode trunk
no snmp trap link-status
GigabitEthernet1/0/6 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 1cde.a72d.a006 (bia 1cde.a72d.a006)
Description: TRANSIT-LAN
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:07, output 00:00:00, output hang never
Last clearing of "show interface" counters 09:22:42
5 minute input rate 152000 bits/sec, 61 packets/sec
5 minute output rate 112000 bits/sec, 71 packets/sec
7922713 packets input, 3350655625 bytes, 0 no buffer
Received 8760 broadcasts (8760 multicasts)
0 watchdog, 8760 multicast, 0 pause input
9285016 packets output, 2400017123 bytes, 0 underruns
0 unknown protocol drops
5 Replies 5
Georg Pauwen
--> ip tcp adjust-mss 1300
looks somewhat odd, what is that for ? Try and remove that line:
--> no ip tcp adjust-mss 1300
Hello
Are you using this interface as part of  PPOE, if so try also to apply the ip mtu to the same size of the ip tcp adjust-mss
int fa0/0
int dialer x
ip mtu 1300
Kind Regards
Paul
Hi Paul,
No I am not using PPoE, it is LAN - LAN, the Switch and router port are connected as LAN, not in WAN. Please refer to my configuration in my original post
Joseph W. Doherty
I suspect the issue might be the 2911 cannot handle a too large burst of packets at full gig (as Cisco recommends it for up to 35 Mbps, duplex). You might try running the interface at 100 Mbps, or perhaps, if both it and the 2960S support flow control, try that.
Hi Joseph,
I will try changing the Flow control and let you know
