Input errors on 6513 and input errors and CRC's on a 3560
djgizmo250
One of our departments are complaining about a "slow" network from one device to another.
Can you help me figure out why I'm getting input errors and CRC's?
Here's the interface on the 6513:
6513#sh int g9/26
GigabitEthernet9/26 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0014.69d9.9081 (bia 0014.69d9.9081)
Description: PACS.DAS119
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
reliability 254/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output 00:00:05, output hang never
Last clearing of "show interface" counters 00:11:21
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 6000 bits/sec, 8 packets/sec
5 minute output rate 8000 bits/sec, 7 packets/sec
5770 packets input, 547560 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
23 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
5312 packets output, 680843 bytes, 0 underruns
6513#
Here's the interface on the 3560:
3560#sh int g0/35
GigabitEthernet0/35 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0017.0ea0.b323 (bia 0017.0ea0.b323)
Description: DAS4
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 246/255, txload 3/255, rxload 1/255
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:10:29
5 minute input rate 543000 bits/sec, 87 packets/sec
5 minute output rate 1428000 bits/sec, 126 packets/sec
55011 packets input, 16326049 bytes, 0 no buffer
Received 5 broadcasts (0 multicast)
2213 input errors, 2213 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 3 multicast, 0 pause input
90548 packets output, 120036928 bytes, 0 underruns
3560#
Mark Yeates
Level 7
Level 7
Typically the errors you are seeing are related to a bad cable. Please check the cables and make sure they haven't been mangled, or crimped improperly.... etc
Here is a good interface troubleshooting guide.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfd6.shtml
Mark
5 Replies 5
Mark Yeates
Level 7
Level 7
Mark
Wow, great! Thank you. I wish I had this a long time ago!
glen.grant
Is there a reason you are restricting 2 gig interfaces to 100 meg ? Can you post a "show run interface g9/26 and sh runn int g0/35 . Myself I would make both sides auto/auto for speed and duplex and let it negotiate 1000 meg. The problem looks to be on output side from the 6513 to the 3560 whether its a patch cable or whatever.
The vendor stated that both interfaces should be set to duplex full and speed 100 in order for their devices to work.
To me it looks like the vendor did not do his side like he told you to, like he left his side as auto and you have your side hardcoded. you can test by doing a extended ping across that link and use like 1400 byte packets and see how many pings drop .
