Input rate and output rate counter disappear on interface
bo2112260285
Hi All
My topology
SWH01(gi0/1)<------------link1-------------->(gi0/1)SWH02
SWH01(gi0/2)<------------link2--------------->(gi0/2)SWH02
The both switch was configured etherchannel and It worked fine before . After I have changed the Etherchannel configuration to PVST configuration on the both switch. SWH02 is root brigde,the link1 is forwarding sate and the link2 is blocking state but when I go show interface gi0/1 on SWH02. The input rate and output rate counter disappear although there are traffic go though this link, because I can query this traffic counter information on a SNMP client. Please help me know and how to resolve this issue.
+SWH01
interface GigabitEthernet0/1
switchport trunk allowed vlan 2116,2301-2310
switchport mode trunk
speed nonegotiate
interface GigabitEthernet0/2
+SWH02
speed nonegotiate
SWH02#show int gi0/1
GigabitEthernet0/1 is up, line protocol is up (connected)
  5 minute output rate 0 bits/sec, 0 packets/s
Thanks and Best Regards
5 Replies 5
Amit Singh
Did you try reverting the old config to see if that chages the behaviour? Which switches are these? What is the IOS running on these switches? Please paste the show version from the switches.
Cheers,
-amit singh
Dear Amit
Thanks for your responding
I can't try revert to the old config because it will affect to our customer. The switch SWH01 be on the our customer side. You can refer the show version below on SWH02
show version
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:43 by nachen
Image text-base: 0x00003000, data-base: 0x01940000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(14r)EA1a, RELEASE SOFTWARE (fc1)
SWH02 uptime is 25 weeks, 3 days, 1 hour, 0 minutes
System restarted at 14:37:05 GMT Mon Jul 26 2010
System image file is "flash:/c3750-advipservicesk9-mz.122-46.SE.bin"
cisco WS-C3750G-24TS (PowerPC405) processor (revision M0) with 118784K/12280K bytes of memory.
Processor board ID CAT1042RH0A
Last reset from power-on
6 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24TS     12.2(46)SE            C3750-ADVIPSERVICESK9-M
     2 28    WS-C3750G-24TS     12.2(46)SE            C3750-ADVIPSERVICESK9-M
Switch 02
Switch Uptime                   : 18 weeks, 1 day, 5 hours, 45 minutes
Base ethernet MAC Address       : 00:24:C3:21:F3:00
P/S: SWH02 is stackable switch which include two 3750 catalyst switch
Please advice
Thank in advance
Hello Bill,
this might be a known software bug of this platform
for example I have the same problem on a stack made of 2 X 3750 with 12.2(40)SE
rates are 0 even if we know traffic is on the interfaces
to be noted that in SNMP tools like MRTG or CACTI is possible to see the traffic loads of these same interfaces because packet and byte counters are still working
Hope to help
Giuseppe
Hi Guiseppe
Thanks for your repply. I will take note about software bug of this flatform
Best Regards
CSCsz18634 matches this behavior and isn't fixed until 12.2(53)SE on the 3750 platform.
-Matt
