Installation error Nexus 1000v
orsonjoon
When I want to install the Nexus 1000v on a standalone ESX1 5.1 installation I get at Step 5. Confirmation the error (see attachment):
Unable to retrieve deployed VM. Please check VC connection
It's an easy setup with 4 vlans on a trunk, and the managment ip of the ESXi server in vlan 1 which is allowed on the trunk.
What am I doing wrong..... Please help..
Phillip Wilson
Will you please get the following from the VSM?
1. Show Module
2. Show SVS connection
Also did you trunk out the packet and control vlan across this same link you are using for management? Best practice would be to seperate the links for management, control and packet from the vm traffic.
This is a new installation, so no VSM is up and running yet...
When using L3 the packet port group is grayed out for some reason, the managment and the control vlan are on the trunk.
Phillip Wilson
Fresh setup I would go with L2 unless you plan on using L3 for a specific reason. You need to build a Standard switch on the ESX host first to bring the Nexus 1000v up on. Once you get the nexus built you can migrate (management,control,packet) back onto itself and do away with the standard switch.
I am getting the same error when trying to deploy a new VSM. Tried Layer 2 standard and custom, adjusted different things but can't get it to work. Getting that same error:
Unable to retrieve deployed VM. Please check VC connection.
I am trying to add the VSM with the name '87457-n1kv01.den03'. I checked the hostd.log file and see a bunch of errors. Any idea how to fix this?
2014-01-31T23:02:02.872Z [50281B70 info 'vm:Vix: [34498 foundryVMPowerOps.c:980]: FoundryVMPowerStateChangeCallback: /vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx']  vmx/execState/val = poweredOff.
2014-01-31T23:02:02.872Z [FF9475B0 verbose 'Default' opID=5755438a-77-db-65-43 user=vpxuser] SetVmHandle /vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx 10485766
2014-01-31T23:02:02.872Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Upgrade is required for virtual machine, version: 7
2014-01-31T23:02:02.876Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Time to gather config: 3 (msecs)
2014-01-31T23:02:02.876Z [50FC2B70 verbose 'Hbrsvc'] Replicator: ReconfigListener triggered for config VM 14
2014-01-31T23:02:02.877Z [50FC2B70 error 'Hbrsvc'] Failed to retrieve VM config (id=14)
2014-01-31T23:02:02.877Z [50FC2B70 error 'Hbrsvc'] Replicator: VmReconfig failed to retrieve replication config for VM 14, ignoring: vim.fault.ReplicationVmConfigFault
2014-01-31T23:02:02.877Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Current VM Tracking state: disabled
2014-01-31T23:02:02.877Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] CheckForOpaqueNetworkImpact: VM instance UUID set in spec: [50197f97-da7f-d145-d8bf-8b41df5732f0]
2014-01-31T23:02:02.877Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] CheckForOpaqueNetworkImpact: opaque network changes in deviceSpec: { [-105->:] [-104->:] [-103->:]}
2014-01-31T23:02:02.878Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Storage policy for disk '/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmdk' not specified.
2014-01-31T23:02:03.265Z [FF9475B0 verbose 'Vmsvc.VmDiskMgr' opID=5755438a-77-db-65-43 user=vpxuser] Disk created successfully.
2014-01-31T23:02:03.267Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Is disk present translated error to vim.fault.GenericVmConfigFault
2014-01-31T23:02:03.267Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Is disk present failed: vim.fault.GenericVmConfigFault
2014-01-31T23:02:03.267Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Is disk present message: Expected device (ide1:0) does not exist.
2014-01-31T23:02:03.268Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Is disk present translated error to vim.fault.GenericVmConfigFault
2014-01-31T23:02:03.268Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Is disk present failed: vim.fault.GenericVmConfigFault
2014-01-31T23:02:03.268Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Is disk present message: Expected device (scsi0:0) does not exist.
2014-01-31T23:02:03.269Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Setting tracking state for disk w. key -102 to false
2014-01-31T23:02:03.269Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] NIC: is present translated error to vim.fault.GenericVmConfigFault
2014-01-31T23:02:03.269Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] NIC: is present failed: vim.fault.GenericVmConfigFault
2014-01-31T23:02:03.269Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] NIC: is present message: Ethernet adapter 'ethernet0' does not exist.
2014-01-31T23:02:03.270Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] NIC: is present translated error to vim.fault.GenericVmConfigFault
2014-01-31T23:02:03.270Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] NIC: is present failed: vim.fault.GenericVmConfigFault
2014-01-31T23:02:03.270Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] NIC: is present message: Ethernet adapter 'ethernet1' does not exist.
2014-01-31T23:02:03.270Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] NIC: is present message: Ethernet adapter 'ethernet2' does not exist.
2014-01-31T23:02:03.271Z [FF9475B0 info 'Vimsvc.ha-eventmgr' opID=5755438a-77-db-65-43 user=vpxuser] Event 213 : Assigned new BIOS UUID (42197e34-23f7-c33f-cf97-6edc92e8a120) to 87457-n1kv01.den03-1 on 87457-esx01.den03 in ha-datacenter
2014-01-31T23:02:03.271Z [FF9475B0 info 'Vimsvc.ha-eventmgr' opID=5755438a-77-db-65-43 user=vpxuser] Event 214 : Assign a new instance UUID (50197f97-da7f-d145-d8bf-8b41df5732f0) to 87457-n1kv01.den03-1
2014-01-31T23:02:03.272Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Setting VM's tracking state to disabled.
2014-01-31T23:02:03.272Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] UpdatePortOnVmReconfigure: _vmInstanceUuidAfter is set to inSpec [50197f97-da7f-d145-d8bf-8b41df5732f0]
2014-01-31T23:02:03.366Z [FF9475B0 info 'vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser]  Reloading config state.
2014-01-31T23:02:03.387Z [FF9475B0 info 'Libs' opID=5755438a-77-db-65-43 user=vpxuser] VMHS: Transitioned vmx/execState/val to poweredOff
2014-01-31T23:02:03.405Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Commit Vigor batch operation successful
2014-01-31T23:02:03.405Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Signalling Commit Vigor batch operation
2014-01-31T23:02:03.405Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Waiting on Commit Vigor batch operation
2014-01-31T23:02:03.405Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Completed Commit Vigor batch operation
2014-01-31T23:02:03.405Z [50FC2B70 verbose 'Hostsvc.DatastoreSystem'] Datastore-Vdisk refresh: scheduling thread after:0 usec
2014-01-31T23:02:03.405Z [4F8E2B70 verbose 'Hostsvc.FSVolumeProvider'] RefreshOneVmfsVolume on /vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994
2014-01-31T23:02:03.413Z [50281B70 info 'vm:Vix: [34498 foundryVMPowerOps.c:980]: FoundryVMPowerStateChangeCallback: /vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx']  vmx/execState/val = poweredOff.
2014-01-31T23:02:03.415Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Time to gather Snapshot information ( read from disk,  build tree): 1 msecs. needConsolidate is false.
2014-01-31T23:02:03.415Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Time to gather snapshot file layout: 0 (msecs)
2014-01-31T23:02:03.415Z [FF9475B0 warning 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] CannotRetrieveCorefiles: VM is in an invalid state
2014-01-31T23:02:03.460Z [4F8E2B70 verbose 'Hostsvc.FSVolumeProvider'] RefreshOneVmfsVolume 5101904b-227e85e8-3e4a-78e7d17c7994 calling ProcessVmfs
2014-01-31T23:02:03.461Z [4F8E2B70 info 'Hostsvc.DatastoreSystem'] RefreshVdiskDatastores: Done refreshing datastores.
2014-01-31T23:02:03.467Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Time to gather config: 52 (msecs)
2014-01-31T23:02:03.468Z [50FC2B70 verbose 'Hbrsvc'] Replicator: ReconfigListener triggered for config VM 14
2014-01-31T23:02:03.470Z [FF9475B0 info 'Libs' opID=5755438a-77-db-65-43 user=vpxuser]  VAAI-NAS :: vmfsNasPlugin: SUCCESSES: RsrvSpace [0] Cln-Full [0] Cln-Lazy [0] cln-DRun [0], Ext-stats [97]
2014-01-31T23:02:03.470Z [FF9475B0 info 'Libs' opID=5755438a-77-db-65-43 user=vpxuser]  VAAI-NAS :: vmfsNasPlugin: FAILURES: RsrvSpace [0] Cln-Full [0] Cln-Lazy [0] cln-DRun [0], Ext-stats [0]
2014-01-31T23:02:03.470Z [FF9475B0 info 'Libs' opID=5755438a-77-db-65-43 user=vpxuser]  VAAI-NAS :: SvaNasPlugin: SUCCESSES: RsrvSpace [0] Cln-Full [0] Cln-Lazy [0] cln-DRun [0], Ext-stats [0]
2014-01-31T23:02:03.470Z [FF9475B0 info 'Libs' opID=5755438a-77-db-65-43 user=vpxuser]  VAAI-NAS :: SvaNasPlugin: FAILURES: RsrvSpace [0] Cln-Full [0] Cln-Lazy [0] cln-DRun [0], Ext-stats [0]
2014-01-31T23:02:03.470Z [FF9475B0 info 'Libs' opID=5755438a-77-db-65-43 user=vpxuser]  VAAI-NAS :: NAS Mapping Used successfully for 120 times
2014-01-31T23:02:03.471Z [FF9475B0 info 'Hostsvc' opID=5755438a-77-db-65-43 user=vpxuser] Lookupvm: World ID not set for VM 14
2014-01-31T23:02:03.471Z [FF9475B0 verbose 'Hbrsvc' opID=5755438a-77-db-65-43 user=vpxuser] Replicator: VmFileProviderCallback VM (id=14)
2014-01-31T23:02:03.472Z [50FC2B70 verbose 'Hbrsvc'] Replicator: VmReconfig ignoring VM 14 not configured for replication
2014-01-31T23:02:03.472Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Fault Tolerance state callback received
2014-01-31T23:02:03.472Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Record/replay state callback received
2014-01-31T23:02:03.474Z [FF9475B0 info 'Libs' opID=5755438a-77-db-65-43 user=vpxuser] Failed to find manifest content in extended config xml.
2014-01-31T23:02:03.474Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Initial tools version: 7:guestToolsNotInstalled
2014-01-31T23:02:03.475Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] State Transition (VM_STATE_INITIALIZING -> VM_STATE_OFF)
2014-01-31T23:02:03.475Z [FF9475B0 verbose 'Hostsvc.HaHost' opID=5755438a-77-db-65-43 user=vpxuser] ModeMgr::End: op = normal, current = normal, count = 3
2014-01-31T23:02:03.475Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Predicted VM overhead: 141684736 bytes
2014-01-31T23:02:03.476Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Max connection count changed from 0 to 40
2014-01-31T23:02:03.476Z [FF9475B0 info 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Initialized virtual machine.
2014-01-31T23:02:03.476Z [FF9475B0 verbose 'Vmsvc.vm:/vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx' opID=5755438a-77-db-65-43 user=vpxuser] Create DONE: /vmfs/volumes/5101904b-227e85e8-3e4a-78e7d17c7994/87457-n1kv01.den03-1/87457-n1kv01.den03-1.vmx
