Installing SDM 2.5 on cisco 2600
ran
Guys i am new to the cisco world.
I am trying to configure SDM 2.5 on a cisco 2600.
I have access via telnet to the router and was able to change the enable password - which i think is level 15 (right?) and setup (and bring up) the ip on the ethernet interface. I can ping - and get response from - the router
Trying to install SDM on the router i need to provide the default username i tried both admin/administrator but SDM can't communicate with the router
Any ideas or shuggestions would be highly appriciated.
thanks
21 Replies 21
Good morning  Ran Bendori
thanks for using our forum
In order  to enable SDM, follow this steps in the router configuration.
1. Assign an IP address to the router:   ip address x.x.x.x y.y.y.y
2. Create a username:                ( username privilege 15 password 0 )
3. Enable Http server:               ( Ip http server)
4. Enable Http secure-server :   (Ip http secure-server )
5. Enable local authentication : (ip http authentication local)
6. Set a enable password :          ( Enable secret cisco)
7. Enable local Authentication : ( Line vty 0 15
                                                       Login local
                                                       privilege level 15
                                                       transport input telnet
                                                        transport input telnet ssh )
Then  to access the SDM, you have to access from the bowser and enter the router's IP
I hope you find this answer useful, if it was satisfactory  for you, please mark the question as Answered.
Greetings,
Johnnatan Rodriguez Miranda.
I have done all that,  But SDM 2.5 will not install on my Router.
Where can i find a list of hardware requierments ?
hi Ran Bendori
You don't have to install the SDM in your router, you have to install it in your pc, then run the program
Thanks for using our forum
Greetings,
johnlloyd_13
Level 9
Level 9
Hi Ran,
Could you post show run? Default router user/password is usually cisco/cisco.
I would agree with Johnatan to run SDM locally on PC since a 2600 router usually has limited memory resources.
Make sure you've got Java installed (usually older version works) when running SDM.
For some reason, even though i assigned an internal IP to the f0/0 i can't ping.
the router is connected of course. Show Run Below
hostname Bagira
enable secret 5 - ************************************
enable password - **********************************
ip subnet-zero
no ip routing
interface FastEthernet0/0
ip address 192.168.1.252 255.255.255.0
no ip route-cache
speed auto
half-duplex
interface Serial0/0
no ip address
no ip route-cache
shutdown
ip classless
no ip http server
ip pim bidir-enable
line con 0
line aux 0
line vty 0 4
password cisco2
login
no scheduler allocate
end
hi ran,
you've got some missing command lines for SDM to work. try following Johnnatan's advice or use this URL:
http://www.cisco.com/en/US/products/sw/secursw/ps5318/prod_installation_guide09186a00803e4727.html#wp70999
conf t
username privilege 15 secret 0
ip http server
make sure your PC and the 2600 FE0/0 are on the same subnet. do a ping to verify network connectivity.
I failed with two things.
1. Setup a level 15 username and address
Bagira#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Bagira(config)#username admin privilege 15 secret 0 password
% Invalid input detected at '^' marker.
2. setup an http secure server (http is running)
Bagira#conf t
Bagira(config)#ip http secure-server
I can ping the router, the cable was diconnected
any idea ?
hmm, that's kinda weird. i've simulated this on a 2621 but didn't replicate the error.
R1(config)#username admin privilege 15 secret 0 password ?
LINE
R1(config)#do sh ver | i IOS
Cisco IOS Software, C2600 Software (C2600-ADVSECURITYK9-M), Version 12.4(1a), RELEASE SOFTWARE (fc2)
could you type 'user' and then hit the tab key?
Yes, Tab works for both user and privilege but doesn't work for secret
should i upgrade the IOS ?
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(5d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 02-Feb-02 03:36 by kellythw
Image text-base: 0x80008088, data-base: 0x80989870
Bagira uptime is 1 hour, 29 minutes
System image file is "flash:c2600-i-mz.122-5d.bin"
cisco 2620 (MPC860) processor (revision 0x00) with 24576K/8192K bytes of memory.
Processor board ID JAD06160F6N (345273346)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Configuration register is 0x2142
probably because your IOS is kinda old.
try using the 'password' keyword instead.
Is there an upgrade for it ?
password did work, the issue know is with telnet and ssh
both are diabled at the moment.
the 2600 platform has already reached its end of support, so you're out of luck doing an upgrade.
were you able to successfully run SDM? if you did, you could actually start using SDM GUI to configure telnet and SSH.
please rate helpful posts. thanks!
No i was unable to get SDM to run
it is asking for SSH and Telnet user name and password, and it is not the same as the user 15 i assigned.
so sdm didn't let me get in.
did you typed the basic command lines to run SDM? you can just uncheck the box which says the device has HTTPS enabled blah..and click the launch button.
could you post the latest show run output?
