Instructions for installing IOS on a sup720
rshum
I can't for the life of me find the instructions on the cisco.com site. Been looking for 2 days. I'm trying to install s72033-adventerprisek9_wan-mz.122-33.SXI1 on a Sup720 that's running 122-33.SXI7. If someone can provide a link for me that would be much appreciated.
3 Accepted Solutions
smogra
Leo Laohoo
You are downgrading from SXI7 to SXI1?  Have you tried SXJ1 first?
Here's the instructions:
1.  Copy the IOS from the TFTP server or compact flash (CF) to the sup-bootflash;
2.  Change the bootstring to something like this:
boot system sup-bootdisk:.bin
3.   Save your config.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Single sup?
If so, load your IOS image where ever you have sufficient space for your image, except for bootflash: (which should be too small for the IOS you want to load).
If insufficient space, free some by deleting or formatting existing storage.  (On older formatted storage, you need to squees the storage after deleting files to actually make the deleted space available.)
Once the IOS is loaded, insure any boot system commands have it as the first or only named boot image.  If no boot system commands, your IOS image must be the first bootable image on the default storage.
Reload system.
PS:
New IOS image can be copied to sup720 storage using copy command or it can be pre-loaded on external compact flash cards.  (When doing the latter, you need to insure the formatting of the card is understood by the sup720.)
5 Replies 5
Latchum Naidu
Hi Rshum,
Please find the below discussion may help you.
http://www.tek-tips.com/viewthread.cfm?qid=1057634&page=7
Please rate the helpful posts.
Naidu.
smogra
This link might interest you:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080116ff0.shtml#sup720
Hope that helps.
Cheers
Sweta
Please rate useful posts.
Leo Laohoo
Joseph W. Doherty
Disclaimer
Posting
Single sup?
Reload system.
PS:
Leo Laohoo
Thank you very much for your ratings.
