inter-VLAN problem
eng_karim
I have configured VTP between two SW  correctly
I have configured inter-VLAN using router correctly
and from any pc from VALN 1 I can ping { itself , any member in VLAN 1 , PC2 & PC3 from VLAN 2 }
but I can't ping PC3 or PC4 from VLAN 2
it seem that it need inter-vlan config but I can't guess what it is
remember I am CCNA learner
6 Replies 6
Jerry Ye
Check your IP configuration and post your config of both switches, and the router. Someone will take a look.
jerry
for SW0
SW0>en
SW0#show vlan bri
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/21
                                                Fa0/22, Fa0/23, Fa0/24, Gig1/2
2    vlan2                            active    Fa0/5, Fa0/6
3    vlan3                            active    Fa0/3, Fa0/4
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
SW0#show int trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/20      on           802.1q         trunking      1
Gig1/1      on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/20      1-1005
Gig1/1      1-1005
Port        Vlans allowed and active in management domain
Fa0/20      1,2,3
Gig1/1      1,2,3
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/20      1,2,3
Gig1/1      1,2,3
SW0#show running
Building configuration...
Current configuration : 1252 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname SW0
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 3
switchport mode access
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 2
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/19
interface FastEthernet0/20
switchport mode trunk
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
For SW1
SW1>en
SW1#show vlan bri
1    default                          active    Fa0/1, Fa0/2, Fa0/5, Fa0/6
                                                Fa0/7, Fa0/8, Fa0/9, Fa0/10
                                                Fa0/11, Fa0/12, Fa0/13, Fa0/14
                                                Fa0/15, Fa0/16, Fa0/17, Fa0/18
                                                Fa0/19, Fa0/20, Fa0/21, Fa0/22
2    vlan2                            active    Fa0/3, Fa0/4
3    vlan3                            active
SW1#show int trunk
Gig1/1      auto         n-802.1q       trunking      1
Gig1/1      1-1005
Gig1/1      1,2,3
Gig1/1      1,2,3
SW1#show running
Current configuration : 1106 bytes
version 12.2
hostname SW1
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
for R1
R1>en
R1#show running
Current configuration : 595 bytes
version 12.2
hostname R1
ip name-server 0.0.0.0
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
interface FastEthernet0/0.2
encapsulation dot1Q 3
ip address 192.168.2.1 255.255.255.0
no ip address
duplex auto
speed auto
ip classless
line con 0
line vty 0 4
login
end
Reza Sharifi
Hi Karim,
Do PC3 and PC4 have the correct defaul gateway?
Also, you have 3 Vlans 1,2, and 3, but I only see 2 sub-interfaces on your router
Reza
In additional to Reza's comments, in SW1, did you forget to put switchport mode trunk on the GE connected to SW0?
HTH,
jerry
I am sorry   I have a mistake in the picture and  in the VLAN assignment for SW1 as I assign PC4 and PC7 for VLAN 2 and really they belong to VLAN 3
all thing are correctly working now
CSCO11167812
Hi Karim,
In your router configuration I see only 2 sub interfaces for VLAN 1 en 3
Try to setup these interfaces correctly and it should work.
Kind regards,
Michel
