Inter Vlan Routing on a Cisco 861 Router
anish.antony
Hi all
I have a Network with 2 Subnets (2 DHCP servers) , Cisco Switch and a Cisco 861 Router.
On the Router
Fa 4 (WAN port) is connected to the ADSL line
All other 4 ports which are layer 2 ports
I need to achieve inter vlan routing
I have created 2 SVI's and assigned the default ip address on these SVI vlans
I have selected fa 3 as the uplink trunk port that connects to the Switch.
The config on the Fa 3 Trunk port is as shown below
switchport mode trunk
switchport trunk encapsulation dot.1q
switchport trunk allowed vlan all
This config does not show up on the Show Run config even though i did configure it. Is that normal ?
so will inter vlan routing work in this way ?
there should be only one connection between switch and router
Many Thanks.
0 Replies 0
